MINIDSP UMA-8 Microphone Module MEMS USB 8 Channel
MiniDSP's UMA-8 v2 is a high-performance, low-cost 8-channel USB microphone built around the XMOS Vocal Fusion (XVF3000) series, with an enhanced adaptive beamformer, full-duplex AEC, and AGC with noise suppression. Seven high-performance MEMS microphones are circularly configured to provide high-quality voice capture for a wide range of applications.
Reference : 16390
159,00 €tax incl.
132,50 € tax excl.
MiniDSP UMA-8
MiniDSP UMA-8 Module microphone MEMS USB 8 canaux
MiniDSP's UMA-8 v2 is a high-performance, low-cost 8-channel USB microphone built around the XMOS Vocal Fusion (XVF3000) series, with an enhanced adaptive beamformer, full-duplex AEC, and AGC with noise suppression. Seven high-performance MEMS microphones are circularly configured to provide high-quality voice capture for a wide range of applications. With on-board DSP processing, the UMA-8 supports speech algorithms such as beamforming, noise reduction, acoustic echo cancellation and de-reverberation. The UMA-8 is a fully compatible UAC2 audio interface with driverless support for Mac/Linux and ASIO drivers for Windows.
This compact platform is designed to offer great flexibility in firmware, software and hardware. Pre-compiled firmware versions; expansion connectors offering connectivity for additional PDM microphones, I2S and GPIO I/O expansion, everything is there to adapt to your use.
Product typeMicrophone board
Number of channel8
Microhphone typeMEMS
Microphone modelKnowles SPH1668LM4H
USB ControllerXMOS XVF3000
DSPBeamforming
Noise reduction
Echo cancellation
De-reverb
Direction of arrival (DOA)
Voice activity detection (VAD)
RGB LEDx11
DimensionsØ90 x 20mm
MiniDSP's UMA-8 v2 is a high-performance, low-cost 8-channel USB microphone built around the XMOS Vocal Fusion (XVF3000) series, with an...
