This reference is very similar to the LD165CR04. The differences reside in the use of an inverted core cache and a voice coil whose impedance of 8 Ohm allows the parallel connection of 2 units.
Ce boomer grave-medium is particularly intended to constitute the serious way of a system 2 or 3 channels bass-reflex of very high level.
Find the complete datasheet in the documents below.
Speaker Power (W RMS) | 90.0 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 160.0 |
Diaphragm type | Paper |
Efficiency / Sensitivity (dB) | 87.0 |
Max Linear Excursion (Xmax) (mm) | 7.0 |
