DAYTON AUDIO CE32A-4 Mini Speaker Driver Full Range 2W 4 Ohm 81dB 240Hz - 20kHz Ø3.2cm
This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for small DIY designs
4.7 / 5
Reference : 12510
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 22-04-2025.
Mini Speaker 4Ω ⌀32mm
Dayton Audio CE32A-4 Mini haut parleur 4ohm 32mm
With the CE32A-4, Dayton Audio offers a small 4? loudspeaker designed to meet a wide range of needs with a very wide frequency range. It will therefore be suitable for the design of many DIY audio projects, especially for small format loudspeakers.
However, this CE32A-4 loudspeaker offers a high quality design with a concave concave anodized aluminum cone, rubber suspension, fabric spider and neodymium magnet.
Speaker typeMini Speaker
Power handlingRMS : 2W
MAX : 4W
Impedance
Sensitivity78dB @ 1W/1m
Frequency response240Hz - 20kHz
Voice coil diameter12.55mm
DC Resistance(Re)3.57Ω
Voice coil Inductance (Le)0.015mH
Resonant frequency (Fs)268.1Hz/td>
Mechanical Q (Qms)2.86
Electromagnetic Q (Qes)1.24
Total Q (Qts)0.86
Diaphragm Mass Inc. Airload (Mms)0.52Mms
Mechanical compliance of suspension (Cms)0.688 mm/N
Surface Area of Cone (Sd)3.917cm²
BL Product (BL)1.59Tm
Compliance equivalent volume (Vas)0.15l
Maximum linear excursion (Xmax)5mm
Diaphragm materialAluminium
Surround materialRubber
Magnet materialNeodymium
Total diameter32mm
Total depth15.5mm
19mm
Voice coil diameter12.5mm
Dayton audio CE32A-4 mini haut parleur
Speaker Power (W RMS)2.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)32.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)81.0
Max Linear Excursion (Xmax) (mm)0.5
Lowest frequency (Hz)240
Highest frequency (Hz)20000
3 reviews
HP de remplacement
Petit HP pour réparer les 2 HP satellites HS d'un ensemble JBL CREATURE. Après avoir raboté les coins du hp il s'est parfaitement intégré au chassis de l'ancien HP. Depuis mon système JBL fonctionne parfaitement tout cela pour un prix plus que modique.
Très satisfait de mon achat reçu très rapidement
This review has been posted for DAYTON AUDIO CE32A-4 Mini Speaker Driver Full Range 2W 4 Ohm 81dB 240Hz - 20kHz Ø3.2cm
Cool
Bon produit mais vraiment petit
excellent !!!
J'ai commandé deux de ces HPs pour remplacer ceux HS d'un écran Dell 2407WFP... à part les 4 trous de fixation que j'ai du agrandir un peu, le résultat est super. De très bonne qualité !
This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for...
