DAYTON AUDIO CE40-28P-8 Mini Speaker Driver Full Range 2W 8 Ohm 75dB 550Hz - 15kHz 2.5 x 5cm
This small economical replacement eliptical speaker allows a wide range of uses and designs. It provides a surprisingly coherent, intelligible rendering on dialogs for flat screens for example.
Strong points :
  • Lightweight paper loudspeaker cone
  • Powerful and compact magnetic neodymium motor
  • Suspension fabric low resonance
  • Easy mounting with 4 fixing holes
  • Rendering pleasant and intelligible
Reference : 12297
5,20 €tax incl.
4,33 € tax excl.
Shipping date: 15-04-2025.
DAYTON-AUDIO CE40-28P-8
DAYTON AUDIO loudspeakers CE40-28P
This economical Dayton Audio CE 40-28-P mini speaker features a powerful neodymium motor and a loudspeaker speaker membrane that produces a fast impulse response. Its plastic injected chassis allows a simplified assembly with its 4 fixing holes.
Its wide bandwidth of 15khz to 600hz allows a wide choice of uses as a replacement loudspeaker for TV or flat screen to the design of mini PC speakers to the development of mini line array for public address thanks to its impedance of 8 Ohm.
Features:
  • Nominal diameter: 40 x 28.5mm
  • Power Handling (RMS): 2 Watts
  • Impedance: 8 ohms
  • Frequency response: 550Hz - 15000kHz
  • Sensitivity: 72dB, 2.83V / 1m
  • Coil Diameter: 2.54cm
  • Resonant Frequency (Fs): 607Hz
  • Resistance DC (Re): 7 ohms
  • Coil Inductance (Le): 0.26 mH
  • Q Mechanical QMS: 3.96
  • Q electromagnetic (Qes): 9.87
  • Q total (Qts): 2.83
  • Compliance volume (Vas): 0.0005 liter
  • Coil diameter: 1.27 mm
  • Mechanical suspension compliance (Cms): 0.177 mm / N
  • BL Product (BL): 1.3 Tm
  • Supported by the diaphragm (Mms): 0.37g
  • Maximum linear excursion (Xmax): 0.1mm
  • Surface area of ​​the cone (Sd): 5.28cm²
Building materials:
  • Cone: Treated paper
  • Suspended material: Non-resonant fabric
  • Neodymium Magnet
  • Reinforced plastic injected frame
Mounting information:
  • Overall external dimension: 40 x 28.5 mm
  • External Depth: 11mm
  • Mounting holes: 4
  • Weight: 22g
 Dayton audio CE40-28-P
Speaker Power (W RMS)2.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)48.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)75.0
Max Linear Excursion (Xmax) (mm)0.1
Lowest frequency (Hz)550
Highest frequency (Hz)15000
This small economical replacement eliptical speaker allows a wide range of uses and designs. It provides a surprisingly coherent, intelligible...
