DAYTON AUDIO DMA80-8 Speaker Driver Full Range Aluminium 25W 8 Ohm 85dB 90Hz - 20kHz Ø7.6cm
Offering high efficiency while maintaining low distortion, the Dayton Audio DMA80-8 Aluminium wideband cone driver is ideal for integration into many compact DIY speaker projects.
Reference : 14098
22,90 €tax incl.
19,08 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
Dayton Audio DMA80-8 Haut-Parleur Large Bande Aluminium 25W 8 Ohm 85dB 90Hz - 20kHz Ø7.6cm />
Designed to deliver the best possible performance, the design of the DMA80-8 allows it to deliver a very wide frequency range with a low level of distortion. The motor uses two Neodymium magnets, creating a strong symmetrical electromagnetic field for high efficiency and excellent membrane control. The magnet assembly also incorporates a Copper part to lower inductance and distortion, resulting in an improved high frequency response. The 1" 2-layer coil is wound on an open Aluminium support providing excellent heat dissipation, allowing the speaker to withstand high power and low power compression. The rubber suspension and wide spider hold the very light aluminium diaphragm in a totally linear manner, while providing excellent mechanical damping. In addition, the Aluminium core cover is directly attached to the coil holder to improve high frequency response with exceptional off-axis performance. The whole is maintained by a 12-branch bowl with an open design, with wide ventilation under the spider and a large space for a high linear excursion.
In addition, Dayton Audio designed the DMA range with DIY speaker designers in mind. Thus, the large mounting surface allows easy positioning, without the need for precision cutting. To facilitate installation, the terminals are oriented so that no cut-outs or notches are required to clear the connectors or wires. Finally, the corners of the speaker have a radius of 1/8", which means that for flush mounting, you can get a perfect fit using any standard 1/4" straight cut drill bit.
Dayton Audio DMA80-8 Haut-Parleur Large Bande Aluminium 25W 8Ω 85dB 90Hz-20000Hz Ø7.6cm
Speaker driver typeFull range
Nominal diameterØ7.6cm
PowerRMS : 25W
Max : 50W
Impedance8Ω
Frequency response90Hz - 20000Hz
Sensitivity85.3dB @ 2.83V/1m
85dB @ 1W/1m
Voice coil diameterØ2.54cm
Weight172g
Thiele-Small Parameters
Resonant frequency (Fs)97.6Hz
DC Resistance (Re)7.5Ω
Voice coil inductance (Le)0.5mH
Mechanical quality coefficient (Qms)2.06
Electromagnetic quality coefficient (Qes)0.61
Total quality coefficient (Qts)0.47
Compliance equivalent volume (Vas)0.04 ft.³
Mechanical compliance of suspension (Cms)0.98mm/N
Force factor (BL)4.52Tm
Diaphragm mass inc. airload (Mms)2.70g
Max linear excursion (Xmax)2.5mm
Surface area of cone (Sd)31.2cm²
Materials
ConeAluminium
SurroundRubber
Voice coil wireCopper
Voice coil formerAluminium
Frame / BasketPolymer
MagnetNeodymium
Mounting informations
Overall external diameter80.3 x 80.3mm
Cutout diameter74.4mm
Depth38.9mm
Bolt circle diameter95.2mm
Number of mounting holes4
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume0.035ft³
Sealed F3174Hz
Vented volume0.053ft³
Vented F391Hz
Speaker Power (W RMS)25.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)76.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)90
Highest frequency (Hz)20000
Offering high efficiency while maintaining low distortion, the Dayton Audio DMA80-8 Aluminium wideband cone driver is ideal for integration into...
