Installés dans des charges BR en tube PVC, franchement le rendu est vraiment convaincant dans une petite pièce.
Excellent rapport qualité-prix
Haut-Parleur Large Bande Aluminium 30W 4 Ohm 89.3dB 85Hz - 20kHz Ø 8.9cm
The Dayton Audio DMA90-4 wideband Dayton Audio DMA90-4 aluminum cone provides excellent performance and low distortion. This speaker can be integrated into many audio projects, from the design of a Bluetooth portable speaker, a sound bar, a PC audio system and much more!
Designed to provide the best performance at a reasonable price, the uncompromising design of the DMA90-4 is capable of reproducing a very wide frequency range while significantly limiting distortion. The speaker motor uses two Neodymium magnets creating a strong symmetrical magnetic field for high efficiency and excellent membrane control. The magnet set also includes a large copper cover with a sheath to reduce inductance and distortion, thus improving the reproduction of high frequencies.
The 2.54cm diameter double layer coil is wound on an open Aluminium support ensuring excellent heat dissipation and high power retention. The rubber suspension and wide Spider hold the Aluminium diaphragm with very good damping. In addition, the Aluminium dome is attached to the coil support, which also improves high-frequency reproduction. The entire loudspeaker is supported by a 12-spoke bowl with an open design, which also allows for a large linear excursion.
When designing the DMA range, Dayton Audio thought of DIY enthusiasts. Thus, the wide edge of the loudspeaker does not require an extremely precise cut-out and thus simplifies assembly. In addition, the terminals are oriented to simplify their wiring.
Product type | Full range speaker driver |
Nominal diameter | 8.89cm |
Power | RMS : 30W Max : 60W |
Impedance | 4 Ohm |
Frequency response | 85Hz - 20kHz |
Sensitivity | 89.3dB 2.83V/1m 86.1dB 1W/1m |
Voice coil diameter | 2.54cm |
Thiele-Small Parameters | |
Resonant frequency (Fs) | 88.15Hz |
DC Resistance (Re) | 3.84 Ohm |
Voice coil inductance (Le) | 0.32mH |
Mechanical Q (Qms) | 2.50 |
Electromagnetic Q (Qes) | 0.56 |
Total Q (Qts) | 0.45 |
Compliance equivalent volume (Vas) | 0.08ft³ |
Mechanical compliance of suspension (Cms) | 1.03mm/N |
BL Product (BL) | 3.5Tm |
Diaphragm Mass Inc. Airload (Mms) | 3.2g |
Maximum linear excursion (Xmax) | 2.5mm |
Surface area of cone (Sd) | 38.5cm² |
Weight | 204g |
Speaker Power (W RMS) | 30 |
Speaker Type | Full range |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 89.0 |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | 89.0 |
Max Linear Excursion (Xmax) (mm) | 2.5 |
Lowest frequency (Hz) | 85 |
Highest frequency (Hz) | 20000 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Thibaut d.
