DAYTON AUDIO DS115-8 Designer Series Speaker Driver Midbass 35W 8 Ohm 85dB 60Hz - 8000Hz Ø10cm
The DAYTON AUDIO DS115-8 from the Designer series has been developed specifically for the speaker designer. It's a range of affordable and attractive loudspeakers that emphasizes performance.
Reference : 12614
29,90 €tax incl.
24,92 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
 Ø 10cm - 35W 8 Ohm -
- Medium Woofer Speaker -
DS115-8 Woofer Dayton Audio
High Fidelity and Power
The DAYTON AUDIO DS115-8 from the Designer series has been developed specifically for the speaker designer. It's a range of affordable and attractive loudspeakers that emphasizes performance. Thanks to a careful design, each loudspeaker in the series is able to provide maximum nominal power at the lowest possible frequencies, without ever exceeding the Xmax value.
These speakers combine useful performance parameters with elegant and sober styling. The transducers in the Designer series, carefully optimized to deliver superb audio reproduction when incorporated into a wide range of subwoofers, showcase the audiophile excellence offered by Dayton Audio.
Réponse en fréquence Dayton Audio DS115-8
TECHNICAL SPECIFICATIONS
General Specifications:
  • Speaker diameter: 10cm (4")
  • Power RMS: 35W
  • Maximum power: 70W
  • Impedance: 8 Ohm
  • Frequency Response: 60Hz to 80kHz
  • Sensitivity: 85.3dB
Caractéristiques techniques Dayton Audio DS115-8
Connection system / Dimensions / Weight:
  • Weight: 850g
  • Output: Stereo speaker terminals
  • Color: Black
Dimensions DS115-8 Dayton Audio
Speaker Power (W RMS)35.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)100.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)60
Highest frequency (Hz)8000
The DAYTON AUDIO DS115-8 from the Designer series has been developed specifically for the speaker designer. It's a range of affordable and...
