DAYTON AUDIO DS90-8 Design Series Speaker Driver Full Range 20W 8 Ohm 84dB 80Hz - 13kHz Ø8cm
This 80mm paper-treated membrane driver has a bandwidth from 80Hz to 13000hz. It is ideal for the design of speakers without passive filters with a linear response in two litres of load.
Reference : 9390
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 24-04-2025.
The Designer Series loudspeakers have been developed specifically in the spirit of the manufacturer.
It's an attractive and affordable line of speakers that is designed to deliver performance.
Dayton Audio's engineers ensure that each speaker in the series is capable of handling the full rated power at the lowest frequency.
These speakers combine performance with elegant style.
Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of speakers, the engineers of the Designer Series have set their sights on excellence.
Features :
  • ominal diameter: 80mm
  • Allowable power (RMS): 20 Watts
  • Permissible power (max): 40 Watts
  • Impedance: 8 ohms
  • Frequency response: 80Hz - 13000kHz
  • Sensitivity: 84.5 dB, 2.83V / 1m
  • Voice Coil Diameter: 0.8".
  • Magnet weight: 8 oz
  • Resonance frequency (Fs): 74.7Hz
  • DC Resistance (Re): 6.5 ohms
  • Coil inductance (Le): 0.58 mH
  • Mechanical Q (QMS): 2.07
  • Electromagnetic Q (Qes): 0.5
  • Total Q (Qts): 0.4
  • Volume compliance (Vas): 0.06 cu. ft.
  • Mechanical suspension compliance (Cms): 1.26 mm / N
  • BL Product (BL): 4.7 Tm
  • Pressure supported by the diaphragm (Mms): 3.6g
  • Maximum linear excursion (Xmax): 2.5mm
  • Cone surface area (Sd): 31.2cm²
Building materials :
  • Cone: Coated paper
  • Suspension material: Rubber
  • Moving Coil: Copper and Aluminium Wire
  • Steel Frame
  • Ferrite magnetcier
  • Aimant ferrite
Mounting information :
  • Overall outer diameter: 92mm
  • Cutting diameter: 70mm
  • Depth: 45mm
  • Mounting holes: 4
  • Weight: 545g
Dayton Audio DS90-8 Spec
Dayton Audio DS90-8 Dimensions
Speaker Power (W RMS)20.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)80.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)84.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)80
Highest frequency (Hz)13000
De petits montres..!
Bonjour,
J'ai installé ces petits haut parleurs dans de petites enceintes labyrinthe Iwistao.
Raccordées à un petit ampli FX audio fx252a et un petit pré ampli FX tube-03, le tout, raccordé à mon téléphone (chambre à coucher). Le son est à peine croyable !
Pour le moment, ils sont utilisés en large bande et ça fait déjà bien le taf. Je vais ensuite rajouter un second ampli, un petit filtre actif et deux tweeters histoire d'élargir la bande.
Sinon, seuls ils sont quand même fabuleux pour le prix..
(Les labyrinthes Iwistao y sont aussi pour bcp pour la réponse dans les graves)
This review has been posted for DAYTON AUDIO DS90-8 Design Series Speaker Driver Full Range 20W 8 Ohm 84dB 80Hz - 13kHz Ø8cm
This 80mm paper-treated membrane driver has a bandwidth from 80Hz to 13000hz. It is ideal for the design of speakers without passive filters with a...
