DAYTON AUDIO DSA90-8 Designer Series Speaker Driver Full Range 20W 8 Ohm 85dB 66Hz - 15kHz Ø7cm
Broad band speaker. Versatile and easy to use. Good solution for beginners in speaker building / tuning
4.5 / 5
Reference : 12713
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 24-04-2025.
Full-range speaker DSA90-8 Dayton Audio
Robustness, ease of installation and high performance sound
Speaker front view with rubber coating membrane and black aluminum
full-range speaker
The DSA90-8 is a full-range speaker which can reproduce most of the audio spectrum. True to the Designer Series by Dayton Audio, it is a highly versatile speaker that will give good results in most contexts and varied configurations. It can thus be used only in compact high performance speakers, or less commons configurations (line-arrays, its bars ... etc.).
Designed for easy installation and clean sound
DSA90-8 audio dayton
 Designer DSA90-8 was thought to facilitate every step in your build from theoric calculations to  assembly and installation.
It is equipped with an additional structure rubber on the front panel to strengthens and protect its cone. Il allows a direct installation in a speaker box without having to oversink.
Its engine is vented and mounted on copper ring to ensure the stability of the signal and minimize thermal stresses. This emphasizes the qualities of the other components of the chain.
Typebroadband
MembraneAluminum
Nominal diameter7.62 cm
Impedance8 ohms
Resistance6.6 ohms
Le0.53 mH @ 1kHz
Fs66.62 Hz
Qms2.15
Qes0.45
Qt0.35
Mms3.5g
cms1.64 mm / N
sd31.2 cm²
Vd7.8 cm²
BL4.61 Tm
Vas2.27 Liters
Xmax2.5 mm
Speaker Power (W RMS)20.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)70.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)66
Highest frequency (Hz)15000
Download
2 reviews
Très satisfait
Je suis satisfait de mon achat, haut parleur avec une fabrication de très bonne qualité, et le son est top.
This review has been posted for DAYTON AUDIO DSA90-8 Designer Series Speaker Driver Full Range 20W 8 Ohm 85dB 66Hz - 15kHz Ø7cm
Petit, mais costaud !
Bonjour,
Ce petit hp est très intéressant !
Testé pour l'instant dans un voume de 5,6 en bass reflex (67 Hz), il est généreux à tout point de vue ! (peut-être un peu trop dans l'aigu).
Il est de bonne facture, et facile à mettre en oeuvre, comme l'indique la page produit.
A l'écoute, il est très détaillé, presque analytique.
J'ai prévu de le tester aussi en 1/4 d'onde, dans un volume plus gros, en ajustant un peu l'accord bass reflex, et en adoucissant peut-être un peu l'aigu.
Ne vous fiez pas à son diamètre, il en fait plus que ce que l'on peut penser.
Cordialement.
