DAYTON AUDIO DW3-1053SC Speaker Driver Full Range 15W 8 Ohm 85dB 100Hz-18kHz Ø7.6cm
The Dayton Audio DW3-1053SC full-range driver features a robust construction with a damped polyethylene cone, flat spider and rubber suspension. The 22mm voice coil provides excellent diaphragm control for linear travel and extended frequency response.
Reference : 15959
33,90 €tax incl.
28,25 € tax excl.
Shipping date: 25-04-2025.
Dayton Audio DW3-1053SC Haut-Parleur Large Bande 15W 8 Ohm 85dB 100Hz-18kHz Ø7.6cm
The Dayton Audio DW3-1053SC full-range driver features a robust construction with a damped polyethylene cone, flat spider and rubber suspension. The 22mm voice coil provides excellent diaphragm control for linear travel and extended frequency response. This wide frequency range ensures easy integration into multi-channel systems. The neodymium magnet combined with plastic heat sinking fins minimizes the weight of the speaker, making it a very good model for use in portable speakers.
Speaker driver typeFull range
Nominal diameterØ76mm (3")
Output powerRMS : 15W
Max : 30W
Impedance8Ω
Frequency response100Hz - 18kHz
Sensitivity85dB 2.83V/1m
Voice coil diameterØ22.2mm (0.875")
Weight181g
Overall external dimensions81 x 50.8mm
Magnet weight-
Resonant frequency (fS)100Hz
DC Resistance (RE)5.98Ω
Electrical quality factor (QES)0.72
Mechanical quality factor (QMS)4.77
Total quality factor (QTS)0.62
Suspension equivalent air volume (VAS)1.13L
Maximum impedance (Zmax)-
Voice coil inductance (LE)0.44mH
Force factor (B·l)-
Suspension mechanical resistance (RMS)-
Suspension mechanical compliance (CMS)-
Moving mass (MMD)-
Moving mass including airload (MMS)-
Surface of the diaphragm (SD)-
Effective diaphragm diameter-
Maximum linear excursion (Xmax)±1.5mm
Displacement volume at Xmax (VD)-
Efficiency (η₀)-
Efficiency bandwidth product (EBP)-
Materials
Diaphragm materialPolyethylene
Surround materialRubber
Frame materialSteel
Magnet materialNeodymium
Mounting informations
Overall external diameterØ81mm
Cutout diameterØ76.2mm
Total depth50.8mm
Mounting bolt circle diameterØ84mm
Number of mounting holes4
Optimum cabinet size (Determined using BassBox 6 Pro High Fidelity)
Sealed volume1.7L
Sealed F3128Hz
Vented volume2.83L
Vented F365Hz
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)76.0
Diaphragm typePolyethylene
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)1.5
Lowest frequency (Hz)100
Highest frequency (Hz)18000
The Dayton Audio DW3-1053SC full-range driver features a robust construction with a damped polyethylene cone, flat spider and rubber suspension....
