DAYTON AUDIO HARB252-8 Speaker Driver Full Range Dual Motor 10W 8 Ohm 77dB 150Hz-17kHz
The unique shape and wide frequency range of the Dayton Audio HARB252-8 dual-motor full-range speaker allows for applications where other speakers simply won't fit. For example, it can be used horizontally as a full-range speaker for a center channel or vertically for desktop speakers.
Reference : 16022
19,90 €tax incl.
16,58 € tax excl.
This product is temporarily unavailable.
Dayton Audio HARB252-8 Haut-Parleur Large Bande Double Moteur 10W 8 Ohm 77dB 150Hz-17kHz Ø12.7cm
Speaker driver typeFull range
Power handlingRMS : 10W
Max : 15W
Impedance8Ω
Frequency response150Hz - 17kHz
Sensitivity77.2dB 2.83V/1m
Voice coil diameterØ16mm (0.63")
Weight90g
Overall external dimensions30 x 130.8mm
Resonant frequency (fS)172.11Hz
DC Resistance (RE)7.2Ω
Electromagnetic quality factor (QES)2.98
Mechanical quality factor (QMS)4.23
Total quality factor (QTS)1.74
Compliance equivalent volume (VAS)0.28L
Force factor (B·l)3.039T·m
Mechanical compliance of suspension (CMS)0.305mm/N
Surface area of cone (SD)21.03cm²
Maximum linear excursion (Xmax)1.25mm
Materials
Cone materialFiberglass
Surround materialRubber
Frame materialPolymer
Magnet materialNeodymium
Voice coil wire materialCopper
Voice coil formerKapton / Polyimide
Mounting informations
Overall outside dimensions30 x 130.8mm
Cutout dimensions25.4 x 120.6mm
Depth29.5mm
Number of mounting holes4
Optimum cabinet size (Determined with BassBox 6 Pro High Fidelity)
Sealed volume0.74L
Sealed F3128Hz
Speaker Power (W RMS)10.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)N/A
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)77.0
Max Linear Excursion (Xmax) (mm)1.0
Lowest frequency (Hz)150
Highest frequency (Hz)17000
The unique shape and wide frequency range of the Dayton Audio HARB252-8 dual-motor full-range speaker allows for applications where other speakers...
