DAYTON AUDIO DMA45-8 Speaker Driver Full Range
Offering high efficiency and low distortion, Dayton Audio's DMA45-8 is a 3.8cm-diameter full-range aluminum cone speaker driver that can be used for a wide range of modern loudspeaker designs. Whether you're designing a portable Bluetooth speaker, a soundbar, a compact desktop speaker or even a high-output line array, the DMA45-8 is the perfect speaker.
Reference : 19961
14,60 €tax incl.
12,17 € tax excl.
This product is temporarily unavailable.
Dayton Audio DMA45-8 Speaker Driver Full Range Dual Magnet 10W 8Ω 77dB 150Hz-20kHz Ø3.8cm
Dayton Audio DMA45-8 : Side view
The DMA45-8's uncompromising design delivers excellent performance. Its motor uses two neodymium magnets to create a powerful, symmetrical magnetic field, ensuring high efficiency and excellent diaphragm control. The magnet assembly also includes a large cap and a copper sleeve to reduce inductance and distortion, improving high-frequency response. The two-layer 19mm voice coil is wound on a ventilated polyimide support, ensuring excellent heat dissipation for high power handling and low power compression. A rubber suspension and large spider hold the aluminum diaphragm in place for perfectly linear movement and excellent mechanical damping. In addition, the aluminum dome is attached directly to the coil support to enhance high-frequency response with exceptional off-axis performance. All this is held in a particularly open 8-spoke bowl, favoring excellent ventilation and high excursion.
What's more, Dayton Audio has designed the front panels of all DMA range loudspeakers with DIY enthusiasts in mind. The oversized mounting flange means no precision cutting is required. For ease of installation, the terminals are oriented so that no cuts or notches are needed to clear connectors or wires.
DAYTON AUDIO DMA45-8 : Measurements and dimensions
Speaker driver typeFull range
Nominal diameterØ38.1mm (1.5")
Power handlingRMS: 10W
Max: 20W
Impedance8Ω
Frequency response150Hz - 20kHz
Sensitivity76.9dB @ 2.83V/1m
Voice coil diameterØ19.05mm (0.75")
Weight68g
Total external dimensions46x46x29.1mm
Magnet weight-
Thiele-Small parameters
Resonant frequency (fS)150.7Hz
DC resistance (RE)7Ω
Voice coil inductance (LE)0.4mH
Mechanical quality factor (QMS)4.59
Electrical quality factor (QES)0.68
Total quality factor (QTS)0.59
Equivalent volume to the compliance (VAS)56.6ml (0.002ft³)
Compliance (CMS)0.6mm/N
Force factor (B·l)4.26T·m
Mechanical resistance (RMS)0.37N·s/m
Moving mass (MMS)1.8g
Moving mass without air load (MMD)1.8g
Max linear excursion (XMAX)2mm
Air volume displaced at Xmax (VD)1.7cm³
Efficiency (η₀)-
Bandwidth efficienct (EBP)-
Effective area (SD)8.6cm²
Materials
ConeAluminum
SurroundRubber
Voice coil wireCopper
Voice coil formerPolyimide
FramePolymer
MagnetNeodymium
Mounting informations
External dimensions46 x 46mm (1.81 x 1.81")
Cutout diameterØ40mm (1.57")
Depth26.1mm (1.02")
Bolt circle diameter50.2mm
Number of mounting holes4
Optimum cabinet size
Sealed volume0.37L (0.013ft³)
Sealed F3207Hz
Vented volume0.28L (0.01ft³)
Vented F375Hz
Speaker Power (W RMS)10.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)38.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)77.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)150
Highest frequency (Hz)20000
DAYTON AUDIO DMA45-8 Speaker Driver Full Range Dual Magnet 10W 8 Ohm 77dB 150Hz-20kHz Ø3.8cm
Offering high efficiency and low distortion, Dayton Audio's DMA45-8 is a 3.8cm-diameter full-range aluminum cone speaker driver that can be...
