DAYTON AUDIO ND105-4 Mid Bass Speaker 4 Ohm Ø10 cm
A midrange bass driver in a compact and sturdy format. Able to produce faithful sounds with a significant dynamic impact.
Reference : 12632
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 24-04-2025.
Speaker ND105-4 Neo Driver 4 Ohm
A midrange bass driver in a compact and sturdy format. Able to produce faithful sounds with a significant dynamic impact. Perfect for adding body and depth to the listening scene of your installation. Suitable for speaker upgrades / repairs or custom builds.
This model is built from the latest excrusion methods, its Polyimide cone makes it a durable and durable accessory. Its low distortion motor and its aluminum diaphragm allow it to withstand the bulk of sound constraints for a natural and clear sound.
The ND105-4 can be used as an independent sound source (speaker only) or as a combined source network (line arrays or sound bars).
Solid and safe construction for multiple uses
ND105-4 Speaker
Despite its small size, the ND105-4 is appreciated for the depth and flexibility of its low frequencies, (although this quality is paradoxically not compatible with the accuracy of the details in the bass). This loudspeaker will therefore give very good results in installations with two speakers (in particular on speakers type MTM).
Speaker TypeMidrange / Bass
PowerRMS : 30 Watts
Max : 60 Watts
Impedance4 Ohms
Dimensions
Frequency Response60-10000 Hz
Sensitivity86,8 cB 2,83V/1m
Voice Coil Diameter1’’
Resonance Frequency78,7 Hz
Nominal Diameter4’’
DC Resistance (Re)3,7 ohms
Voice Coil Inductance (Le)0,76 mH
Electromagnetic Q (Qes)0,66
Mechanical Q (Qms)7,42
Total Q (Qts)0,61
Diaphragm Mass (including Airload) (Mms)7,4 g
Mechanical Compliance of Suspension0,55 mm/N
Surface Area of Cone51,5 cm²
Maximum Linear Excursion4 mm
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (mm)100.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)60
Highest frequency (Hz)10000
DAYTON AUDIO ND105-4 Speaker Driver Midbass Aluminium 30W 4 Ohm 87dB 60Hz - 10kHz Ø10cm
