DAYTON AUDIO ND105-8 Speaker Driver Midbass Aluminium 30W 8 Ohm 83dB 60Hz - 10kHz Ø10.2cm
The Dayton Audio ND105-8 low-frequency midrange driver incorporates a rigid and extremely lightweight aluminium diaphragm, capable of significant linear excursion for such a compact size. A balanced Neodymium motor effectively limits distortion.
Reference : 13659
32,90 €tax incl.
27,42 € tax excl.
Last items in stock !
Shipping date: 29-04-2025.
DAYTON AUDIO ND105-8 Haut-Parleur Bas Médium 30W 8 Ohm 83dB 60Hz - 10kHz Ø10.2cm
The Dayton Audio ND105-8 low-frequency midrange driver incorporates a rigid and extremely lightweight aluminium diaphragm, capable of significant linear excursion for such a compact size. A balanced Neodymium motor effectively limits distortion. The combination of these two technologies makes it possible to obtain a loudspeaker with an impressive sound reproduction due to its dynamism.
Product typeMidbass Speaker Driver
Nominal diameter10.16cm (4")
PowerRMS : 30W
Max : 60W
Impedance8 Ohm
Frequency response60Hz - 10kHz
Sensitivity82.7dB 2.83V/1m
Voice coil diameter2.54cm
Thiele-Small Parameters
Resonant frequency (Fs)66.6Hz
DC Resistance (Re)7.7 Ohm
Voice coil inductance (Le)1.25mH
Mechanical quality coefficient (Qms)5.57
Electromagnetic coefficient quality (Qes)0.74
Total quality coefficient (Qts)0.66
Compliance equivalent volume (Vas)0.104 ft³
Mechanical compliance of suspension (Cms)0.84mm/N
Force factor (BL)0.84Tm
Diaphragm mass inc. airload (Mms)6.8g
Max linear excursion (Xmax)4mm
Surface area of cone (Sd)51.5cm²
Materials
ConeAluminium
SurroundRubber
Voice coil wireCopper
Voice coil formerKapton / Polyimide
FrameSteel
MagnetNeodymium
Mounting informations
Overall outside diameter10.49cm (4.13")
Cutout diameter9.2cm (3.66")
Depth6.7cm (2.64")
Number of fixation holes4
Optimum Cabinet Size (Determined using BassBox 6 Pro)
Sealed Volume0.18ft³
Sealed F385Hz
Vented Volume0.35ft³
Vented F343Hz
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)102.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)60
Highest frequency (Hz)10000
The Dayton Audio ND105-8 low-frequency midrange driver incorporates a rigid and extremely lightweight aluminium diaphragm, capable of significant...
