DAYTON AUDIO ND64-16 Speaker Driver Full Range 15W 16 Ohm 80dB 100Hz-20kHz Ø6.3cm
The Dayton Audio ND64-4 is a full-range loudspeaker, capable of a large linear excursion of 6mm peak-to-peak. It features a dual neodymium magnet structure, a 19mm diameter CCAW voice coil and a copper tube to minimize distortion.
Reference : 16000
23,90 €tax incl.
19,92 € tax excl.
This product is temporarily unavailable.
Dayton Audio ND64-16
Dayton Audio ND64-16 Haut-Parleur Large Bande 15W 16 Ohm 80dB 100Hz-20kHz Ø6.3cm
The Dayton Audio ND64-16 is a full-range loudspeaker, capable of a large linear excursion of 6mm peak-to-peak. It features a dual neodymium magnet structure, a 19mm diameter CCAW voice coil and a copper tube to minimize distortion. The neodymium motor is combined with a rigid yet lightweight aluminum-magnesium diaphragm for a dynamic and punchy sound. The ND64-16 is perfect for use in single driver speaker designs as well as in multi-way speakers.
Speaker driver typeFull range
Nominal diameterØ63mm (2.5")
Power handlingRMS : 15W
Max : 30W
Impedance16Ω
Frequency response100Hz - 20kHz
Sensitivity80.2dB 2.83V/1m
Voice coil diameterØ19m (0.75")
Weight159g
Overall external dimensions64 x 38.8mm
Magnet weight-
Resonant frequency (fS)101Hz
DC Resistance (RE)14.5Ω
Electrical quality factor (QES)0.45
Mechanical quality factor (QMS)4.1
Total quality factor (QTS)0.41
Suspension equivalent air volume (VAS)0.53L
Maximum impedance (Zmax)-
Voice coil inductance (LE)1.21mH
Force factor (B·l)6.54T·m
Suspension mechanical resistance (RMS)0.3N·s/m
Suspension mechanical compliance (CMS)1650µm/N
Moving mass (MMD)2.1g
Moving mass including airload (MMS)2.11g
Surface of the diaphragm (SD)15.6cm²
Effective diaphragm diameterØ4.5cm
Maximum linear excursion (Xmax)±1.9mm
Displacement volume at Xmax (VD)3cm³
Efficiency (η₀)0.12%
Efficiency bandwidth product (EBP)224
Materials
Diaphragm materialAnodized aluminum
Surround materialRubber
Magnet materialNeodymium
Frame materialSteel
Mounting informations
Overall external diameterØ64mm
Cutout diameterØ53mm
Total depth39mm
Mounting bolt diameterØ66mm
Number of mounting holes4
Optimum cabinet size (determined with BassBow 6 Pro High Fidelity)
Sealed volume0.14L
Sealed F3210.8Hz
Vented volume0.42L
Vented F3111.2Hz
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)16
Loudspeaker diameter (mm)63.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)80.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)100
Highest frequency (Hz)20000
The Dayton Audio ND64-4 is a full-range loudspeaker, capable of a large linear excursion of 6mm peak-to-peak. It features a dual neodymium magnet...
