DAYTON AUDIO ND64-4 Speaker Driver Full Range 15W 4 Ohm 85dB 100Hz-20kHz Ø6.3cm
The Dayton Audio ND64-4 is a full-range loudspeaker, capable of a large linear excursion of 6mm peak-to-peak. It features a dual neodymium magnet structure, a 19mm diameter CCAW voice coil and a copper tube to minimize distortion.
Reference : 15999
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 24-04-2025.
Dayton Audio ND64-4
Dayton Audio ND64-4 Haut-parleur large bande 15W 4 Ohm 85dB 100Hz-20kHz Ø6.3cm
The Dayton Audio ND64-4 is a full-range loudspeaker, capable of a large linear excursion of 6mm peak-to-peak. It features a dual neodymium magnet structure, a 19mm diameter CCAW voice coil and a copper tube to minimize distortion. The neodymium motor is combined with a rigid yet lightweight aluminum-magnesium diaphragm for a dynamic and punchy sound. The ND64-4 is perfect for use in single driver speaker designs as well as in multi-way speakers.
Tang Band W3-1876S Haut-Parleur Subwoofer 15W 4 Ohm 76dB 55Hz-2kHz Ø7.6cm
Speaker driver typeFull range
Nominal diameterØ63mm (2.5")
Power handlingRMS : 15W
Max : 30W
Impedance4Ω
Frequency response100Hz - 20kHz
Sensitivity85.2dB 2.83V/1m
Voice coil diameterØ19m (0.75")
Weight159g
Overall external dimensions64 x 38.8mm
Magnet weight-
Resonant frequency (fS)103Hz
DC Resistance (RE)3.7Ω
Electrical quality factor (QES)0.36
Mechanical quality factor (QMS)4.36
Total quality factor (QTS)0.33
Suspension equivalent air volume (VAS)0.42L
Maximum impedance (Zmax)-
Voice coil inductance (LE)0.37mH
Force factor (B·l)4.13T·m
Suspension mechanical resistance (RMS)0.4N·s/m
Suspension mechanical compliance (CMS)930µm/N
Moving mass (MMD)2.5g
Moving mass including airload (MMS)2.56g
Surface of the diaphragm (SD)15.6cm²
Effective diaphragm diameterØ4.5cm
Maximum linear excursion (Xmax)±1.9mm
Displacement volume at Xmax (VD)3cm³
Efficiency (η₀)0.12%
Efficiency bandwidth product (EBP)286
Materials
Diaphragm materialAnodized aluminum
Surround materialRubber
Magnet materialNeodymium
Frame materialSteel
Mounting informations
Overall external diameterØ64mm
Cutout diameterØ53mm
Total depth39mm
Mounting bolt diameterØ66mm
Number of mounting holes4
Optimum cabinet size (determined with BassBow 6 Pro High Fidelity)
Sealed volume0.06L
Sealed F3265.5Hz
Vented volume0.14L
Vented F3117.3Hz
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)63.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)100
Highest frequency (Hz)20000
The Dayton Audio ND64-4 is a full-range loudspeaker, capable of a large linear excursion of 6mm peak-to-peak. It features a dual neodymium magnet...
