DAYTON AUDIO ND65-8 Speaker Driver Full Range Aluminium 15W 8 Ohm 81dB 80Hz - 20kHz Ø6.3cm
With its low distortion motor mounted on a Neodymium magnet, its high excursion design and its lightweight, solid aluminum diaphragm construction, the ND65-8 wideband speaker has everything you need to easily integrate into your very compact speaker construction/repair projects.
Reference : 13037
27,90 €tax incl.
23,25 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
DAYTON AUDIO ND65-8
Full-range speaker Aluminium 8 Ohm Ø 6.3cm
Dayton Audio ND65-8 Haut-parleur large bande Aluminium
Its minimal diameter (64mm in total) as well as its optimized depth (48mm) allow it to be integrated in projects requiring good performances while remaining very little greedy in space. The loudspeaker also has an extremely low weight (181g). This model is therefore ideal for making simple speakers (a single loudspeaker) and for building nomadic systems with a very wide frequency response.
Speaker typeFull-range
Nominal diameter6.3cm (2.5")
PowerRMS : 15W
Max : 30W
Impedance8 Ohm
Frequency response80Hz - 20000Hz
Sensitivity80.8dB 2.83V/1m
Voice coil diameter1.9cm (0.75")
Measurements
Resonant frequency (Fs)77.4Hz
DC resistance (Re)7.4 Ohm
Voice coil inductance (Le)1.04mH
Mechanical Q (Qms)4.01
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.41
Compliance equivalent volume (Vas)0.02ft.³
Mechanical compliance of suspension (Cms)1.68mm/N
BL Product (BL)4.47Tm
Diaphragm mass inc. airload (Mms)2.5g
Maximum linear excursion (Xmax)3.5mm
Surface area of cone (Sd)15.6cm²
Materials
Cone materialAluminium
Surround materialRubber
Voice coil formerKapton / Polyimide
Magnet materialNeodymium
Mounting informations
Overall outside diameter6.35cm (2.5")
Baffle cutout diameter5.21m (2.05")
Depth5.08cm (2")
Number of mounting holes4
Optimum cabinet size (determined using BassBox 6 Pro)
Sealed volume0.02ft.³
Sealed F3111Hz
Vented volume0.05ft.³
Vented F355Hz
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)63.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)81.0
Max Linear Excursion (Xmax) (mm)3.5
Lowest frequency (Hz)80
Highest frequency (Hz)20000
Positive experience with small speakers
The sales service was excellent, the product arrived quickly, intact and well packaged. As for the speakers... I have yet to test them thoroughly but they seem to work very well.
This review has been posted for DAYTON AUDIO ND65-8 Speaker Driver Full Range Aluminium 15W 8 Ohm 81dB 80Hz - 20kHz Ø6.3cm
With its low distortion motor mounted on a Neodymium magnet, its high excursion design and its lightweight, solid aluminum diaphragm construction,...
