Dayton Audio ND90-8 Speaker Driver Full-Range
Dayton Audio's compact aluminum cone drivers demonstrate the latest advances in high-excursion design processes. An efficient, low-distortion Neo-Balanced motor is combined with a rigid yet lightweight aluminum diaphragm, yielding impressive high-impact audio reproduction. Perfect for single point-source applications, or combined in multiples and line arrays.
Reference : 18764
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 08-05-2025.
Dayton Audio ND90-8 Speaker Driver Full-Range Aluminum 20W 8Ohm 81dB 80Hz-15kHz Ø8.9cm
Dayton Audio ND90-8 : Front view
Robustness, easy to install and high sound performance
Dayton Audio ND90-8 : Measurements
Highlight :
  • Direct replacement for Aura NS3
  • Rubber-edged anodized aluminum alloy cone
  • Large excursion capability—4 mm Xmax, 20 mm peak
  • Full-range 80 Hz to 15 kHz performance
  • 20 watts RMS power handling
TypeFull-Range
Cone / Diaphragm MaterialAluminum
Nominal diameter8.9 cm
Impedance8 ohms
Resistance7.5 ohms
Voice coil inductance (Le)1.08 mH @ 1 kHz
Resonant frequency (Fs)70.7 Hz
Mechanical quality factor (Qms)4.71
Electromagnetic quality factor (Qes)0.75
Total quality factor (Qts)0.65
Diaphragm mass inc. airload (Mms)4.2g
Mechanical compliance of suspension (Cms)1.22 mm/N
Surface area of cone (Sd)31.2 cm²
Volume of displacement (Vd)12.5 cm³
Force factor (BL)4.3 Tm
Compliance equivalent volume (Vas)1.77 Litres
Maximum linear excursion (Xmax)4 mm
Voice coil diameter19 mm
SPL81.4 dB @ 2.83V/1m
Power handlingRMS : 20W
Max : 40W
Usable Frequency Range80 - 15000Hz
Speaker Power (W RMS)
  • 20.0
Speaker Type
  • Full range
Impedance (Ω)
  • 8
Loudspeaker diameter (mm)
  • 89.0
Diaphragm type
  • Aluminium
Efficiency / Sensitivity (dB)
  • 81.0
Max Linear Excursion (Xmax) (mm)
  • 4.0
Lowest frequency (Hz)
  • 80
Highest frequency (Hz)
  • 15000
DAYTON AUDIO ND90-8 Speaker Driver Full-Range Aluminum 20W 8Ohm 81dB 80Hz-15kHz Ø8.9cm
Dayton Audio's compact aluminum cone drivers demonstrate the latest advances in high-excursion design processes. An efficient, low-distortion...
