DAYTON AUDIO ND91-8 Speaker Driver Full Range 30W 8 Ohm 82dB 65Hz - 17kHz Ø10cm
The ND91-8 is a full-range speaker featuring a low distortion motor mounted on a ferrite magnet.
Reference : 13069
35,90 €tax incl.
29,92 € tax excl.
Shipping date: 24-04-2025.
Dayton Audio ND91-8
Full-range speaker 8 ohm 10.35 cm
Dayton Audio Speaker ND91-8 medium wide strip
The ND91-8 is a full-range speaker featuring a low distortion motor mounted on a ferrite magnet . With a wide frequency response (65Hz - 17kHz),  well-defined bass impact and low distortion, it is an excellent compromise for any simple modification / repair project.
Driver design adress both power and precision requirement  thanks to a sophisticated design involving a structure copper alloy ring and a underhung coil, allowing increased linearity in movement within the magnetic field.
30 watts (RMS) of power with a 5.1 mm excursion (XMax) in small dimensions (103 x 60.8 cm) make this loudspeaker a balanced and versatile system that can be used both in a single enclosure assembly as in more complex project ( such as line-arrays ...)
Type-Haut parleur large bande
Nominal Diameter-3.5"
Power handling-RMS : 30W
Peak ; 60W
Impedance-8 Ohms
Frequency Response-65 Hz - 17 kHz
Voice Coil InductanceLe1.24mH @ 1kHz
DC ResistanceRe7.8 Ohms
Resonant FrequencyFs70.7 Hz
Mechanical QQms4.29
Electromagnetic QQes0.53
Total QQts0.47
Diaphragm Mass Inc. AirloadMms4.8 g
SensitivitySPL82.1 dB @ 2.83V/1m
Mechanical Compliance of Suspension Cms1.05 mm/N
Surface Area Of ConeSd30.4 cm²
Volume of DisplacementVd12.2 cm³
Compliance Equivalent VolumeVas1.53 Litre
Maximum Linear ExcursionXmax5.1 mm
Voice Coil Diameter-25 mm
Materials-Cone - Aluminium
Surrounding - Gomme
Basket - Acier
Coil Former - Polyimide
Magnet - Ferrite
Overal Diameter-103.5 mm
Overall Depth-56.4 mm
Cutout diameter-85 mm
Mounting holes-x4
Speaker Power (W RMS)30
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)102.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)82.0
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)70
Highest frequency (Hz)17000
