DAYTON AUDIO PRO ODEUM 6.5N Speaker Driver Midbass Neodymium 200W 8Ω 94dB 90Hz - 8000Hz Ø16.5cm
The Dayton Audio Odeum Apollo 6 is a 16.5cm midbass driver supporting power ratings up to 200W RMS. It is equipped with a neodymium magnet motor, a 50.8mm voice coil with glass fiber support and a copper faraday ring to lower the distortion level.
Reference : 16926
189,00 €tax incl.
157,50 € tax excl.
This product is temporarily unavailable.
Dayton Audio PRO Odeum 6.5N neodymium
Dayton Audio Odeum Apollo 6 Haut-Parleur Médium Néodyme 200W 8Ω 94dB 90Hz - 8000Hz Ø16.5cm
Using the knowledge gained from decades of loudspeaker design and engineering, Dayton Audio with its Odeum range, focuses on technical excellence, product reliability and innovation. The Apollo 6 is a 16.5cm midbass driver supporting power ratings up to 200W RMS. It is equipped with a neodymium magnet motor, a 50.8mm voice coil with glass fiber support and a copper faraday ring to lower the distortion level. The coated paper diaphragm with M-Roll surround offers a neutral tone that is easy to tune. The peripheral ventilation system ensures perfect temperature control.
Speaker driverMidbass
Nominal diameterØ165.1mm (6.5")
Power handlingRMS : 200W
Max : 400W
Impedance8Ω
Frequency response90Hz - 8000Hz
Sensitivity94.4dB @ 2.83V/1m
Voice coil diameterØ50.8mm (2")
Weight2.18kg
Overall outside diameterØ167.5 * 84.5mm
Voice coil weight-
Thiele-Small Parameters
Resonant frequency (fS)102.8Hz
DC Resistance (RE)6.06Ω
Voice coil inductance (LE)1.29mH
Mechanical quality factor (QMS)8.02
Electromagnetic quality factor (QES)0.29
Total quality factor (QTS)0.28
Compliance equivant volume (VAS)3.4L (0.12ft³)
Mechanical compliance of suspension (CMS)0.141mm/N
Force factor (B·l)14.94T·m
Mechanical resistance (RMS)-
Diaphragm mass inc. airload (MMS)16.92g
Moving mass (MMD)-
Maximal linear excursion (XMAX)3.77mm
Displacement volume at Xmax (VD)-
Efficiency (η₀)-
Efficiency bandwdith product (EBP)-
Surface area of cone (SD)132.67cm²
Material
DiaphragmCoated paper
SurroundPaper
Voice coil wire-
Voice coil formerFiberglass
Frame-
MagnetNeodymium
Mounting informations
External diameterØ167.50mm
Cutout diameterØ146mm
Depth84.5mm
Mouting circle diameter-
Number of mounting holes4
Speaker Power (W RMS)200.0
Speaker TypeMidrange
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)90
Highest frequency (Hz)8000
The Dayton Audio Odeum Apollo 6 is a 16.5cm midbass driver supporting power ratings up to 200W RMS. It is equipped with a neodymium magnet motor, a...
