DAYTON AUDIO PA130-16 Speaker Driver Full Range 50W 16 Ohm 85dB 80Hz - 15kHz Ø12.7cm
The Dayton Audio PA130-16 is an inexpensive 16Ω wideband speaker, designed for use in small stage monitors, to replace a defective speaker or for a new construction.
Reference : 12759
31,90 €tax incl.
26,58 € tax excl.
This product is temporarily unavailable.
Full Range Speaker 16Ω Ø 12.7cm
The Dayton Audio PA130-16 is an inexpensive 16Ω wideband speaker, designed for use in small stage monitors, to replace a defective speaker or for a new construction. The wide frequency range reproduced by this loudspeaker and its flat curve in the midrange allow it to offer a very nice sound transparency, especially on voices and instruments. This model also features a robust quality construction with a steel frame, a paper membrane, a treated fabric suspension and a wide magnet weighing 567g. Its 16Ω impedance also makes it an ideal speaker for mounting with two speakers.
Speaker typeFull range
Nominal diameter5" (12.7cm)
Power Handling : RMS50W
Power Handling : Max100W
Impedance16Ω
Sensitivity84.8dB 2.83V/1m
Frequency response80Hz - 15kHz
Voice coil diameter1" (2.54cm)
Magnet weight567g (20oz)
DC Resistance (Re)14.1Ω
Voice coil inductance (Le)0.57mH @ 1kHz
Resonant frequency (Fs)78.7Hz
Mechanical Q (Qms)4.37
Electromagnetic Q (Qes)0.71
Total Q (Qts)0.61
Diaphragm Mass Inc. Airload (Mms)6.8g
Mechanical Compliance of Suspension (Cms)0.61mm/N
Surface Area of Cone (Sd)73.9cm²
BL Product (BL)8.14Tm
Compliance equivalent volume (Vas)0.18ft³ (5.49cm³)
Maximum linear excursion (Xmax)2mm
Cone materialPaper
Surround materialClothe
Voice coil wire materialCopper
Voice coil materialAluminium
Basket materialSteel
Magnet materialFerrite
Overall outside diameter13.21cm (5.2")
Overall depth6.76cm (2.66")
Cutout diamter11.2cm (4.41")
Fixation holes4
Dayton Audio PA130-16 Spécifications
Speaker Power (W RMS)50.0
Speaker TypeFull range
Impedance (Ω)16
Loudspeaker diameter (mm)127.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)80
Highest frequency (Hz)15000
The Dayton Audio PA130-16 is an inexpensive 16Ω wideband speaker, designed for use in small stage monitors, to replace a defective speaker or for a...
