DAYTON AUDIO PA130-8 Speaker Driver Full Range 50W 8 Ohm 88.2dB 90Hz - 15kHz Ø12.7cm
The Dayton Audio PA130-8 is a good speaker at a low price, which can be used as a replacement for a defective model or for DIY speaker design. The wide covered frequency range and flat response in the mediums ensure accurate reproduction of voices and instruments.
Reference : 13706
31,90 €tax incl.
26,58 € tax excl.
Shipping date: 25-04-2025.
Haut-Parleur Large Bande 50W 8 Ohm 88.2dB 90Hz - 15kHz Ø12.7cm
Dayton Audio PA130-8 Haut-Parleur Large Bande 50W 8 Ohm 88.2dB 90Hz - 15kHz Ø12.7cm
The Dayton Audio PA130-8 is a good speaker at a low price, which can be used as a replacement for a defective model or for DIY speaker design. The wide covered frequency range and flat response in the mediums ensure accurate reproduction of voices and instruments. This loudspeaker includes a steel bowl, a paper membrane, a fabric suspension and a large 567g magnet.
Speaker driver typeFull Range
Nominal diameterØ12.7cm (5")
PowerRMS : 50W
Max : 100W
Impedance8 Ohm
Frequency response90Hz - 15kHz
Sensitivity88.2dB 2.83V/1m
Voice coil diameterØ25mm
Magnet weight567g
Thiele-Small Parameters
Resonant frequency (Fs)83.4Hz
DC Resistance (Re)7.1 Ohm
Voice coil inductance (Le)0.71mH @ 1kHz
Mechanical quality coefficient (Qms)3.21
Electromagnetic quality coefficient (Qes)0.6
Total quality coefficient (Qts)0.51
Compliance equivalent volume (Vas)3.95L
Mechanical compliance of suspension (Cms)0.54mm/N
Force factor (BL)6.44Tm
Diaphragm mass inc. airload (Mms)6.8g
Maximum linear excursion (Xmax)2mm
Surface area of cone (Sd)73.9cm²
Materials
Cone materialPaper
Surround materialCloth
Voice coil wire materialCopper
Voice coil formerAluminium
Frame materialSteel
Magnet materialFerrit
Mounting informations
Overall outside diameter132mm
Baffle cutout diameter112mm
Depth67.5mm
Number of mounting holes4
Optimum cabinet size (measured with BassBox 6 Pro)
Sealed volume0.07ft³
Sealed F3161Hz
Vented volume0.24ft³
Vented F380Hz
Speaker Power (W RMS)50.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)127.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)90
Highest frequency (Hz)15000
Haut-parleurs de très bonne qualité
J'ai acheté ces haut-parleurs pour faire une paire d'Auratone DIY, et bien je suis bluffé du rendu. J'en ai fait plusieurs avec des caissons de taille différentes car pour copier des Auratone, le volume de la caisse est théoriquement trop petit par rapport aux spécifications constructeur. J'ai le sentiment que de respecter le volume donne un peu plus d'air, elles sonnent un peu plus vivantes.
Quand on regarde la courbe de réponse, on voit qu'elles sont très linéaires et c'est ce que je cherche. On arrive à entendre quand même du bas vers les 80Hz. Le gros + concerne toute la bande de bas et haut medium sur lesquels on a une super lisibilité, on entend les instruments avec beaucoup de détails, les effets de spécialisation ressortent très bien. Ca n'est jamais agressif.
Vraiment idéal pour trouver l'équilibre des instruments dans un mix entre le clair / obscure.
Pour le prix je suis bluffé et très content de mon investissement, je serais curieux d'entendre la différence avec des haut-parleurs de gamme supérieur.
Comme tout haut-parleur, ils ont besoin d'un temps de rodage car au début ça sonne assez dur, un peu de patience...
This review has been posted for DAYTON AUDIO PA130-8 Speaker Driver Full Range 50W 8 Ohm 88.2dB 90Hz - 15kHz Ø12.7cm
The Dayton Audio PA130-8 is a good speaker at a low price, which can be used as a replacement for a defective model or for DIY speaker design. The...
