DAYTON AUDIO PA200-8 Speaker Driver Woofer / Midbass 250W 8 Ohm 92.4dB 70Hz - 9kHz Ø20.3cm
The Dayton Audio PA200-8 is a professional woofer / midbass speaker capable of supporting high power levels using an open system. The motor structure dissipates the heat from the coil and helps to reduce the compression power.
Reference : 13704
69,90 €tax incl.
58,25 € tax excl.
This product is temporarily unavailable.
Dayton Audio RS75-8 Haut-Parleur Large Bande 15W 8 Ohm 80.5dB 160Hz - 20kHz Ø7.6cm
The use of a 50mm diameter Ceramic Ferrite magnet provides a wide and flat frequency response and low distortion. In addition, the use of Copper at the polarized part reduces parasitic eddy currents and minimizes coil inductance.
The sturdy, low mass carbon fibre impregnated paper membrane and the 1.2mm thick steel salad bowl give this speaker a high resistance, perfect for use in concerts, while providing deep and punchy bass.
Dayton Audio PA200-8 Haut-Parleur de Graves 250W 8 Ohm 92.4dB 70Hz - 9kHz Ø20.3cm
Speaker driver typeWoofer / Midbass
Nominal diameterØ20.32cm (8")
PowerRMS : 250W
Max : 500W
Impedance8 Ohm
Frequency response70Hz - 9kHz
Sensitivity92.4dB 2.83V/1m
Voice coil diameterØ50mm
Thiele-Small Parameters
Resonant frequency (Fs)55.2Hz
DC Resistance (Re)6.2 Ohm
Voice coil inductance (Le)1.09mH
Mechanical quality coefficient (Qms)6.17
Electromagnetic quality coefficient (Qes)0.51
Total quality coefficient (Qts)0.48
Compliance equivalent volume (Vas)26.6L
Volume of displacement (Vd)0.631cm³
Mechanical compliance of suspension (Cms)0.4mm/N
Force factor (BL)9.28Tm
Diaphragm mass inc. airload (Mms)20.5g
Maximum linear excursion (Xmax)3mm
Surface area of cone (Sd)210.4cm²
Materials
Cone materialPaper / Kevlar
Surround materialCloth
Voice coil formerKapton / Polyimide
Frame materialSteel
Magnet materialFerrit
Mounting informations
Overall outside diameter210mm
Baffle cutout diameter182mm
Depth108mm
Bolt circle diameter201.9mm
Number of mounting holes8
Optimum cabinet size (measured with BassBox 6 Pro)
Sealed volume0.57ft³
Sealed F396Hz
Vented volume1.1ft³
Vented F348Hz
Speaker Power (W RMS)
  • 250.0
Speaker Type
  • Midbass
  • Woofer
Impedance (Ω)
  • 8
Loudspeaker diameter (mm)
  • 203.0
Diaphragm type
  • Paper
Efficiency / Sensitivity (dB)
  • 92.0
Max Linear Excursion (Xmax) (mm)
  • 3.0
Lowest frequency (Hz)
  • 70
Highest frequency (Hz)
  • 9000
The Dayton Audio PA200-8 is a professional woofer / midbass speaker capable of supporting high power levels using an open system. The motor...
