DAYTON AUDIO PA255-8 Speaker Driver Woofer / Midbass 300W 8 Ohm 96.2dB 46Hz - 3500kHz Ø25.4cm
Reference : 13703
89,00 €tax incl.
74,17 € tax excl.
Last items in stock !
Shipping date: 25-04-2025.
Dayton Audio PA255-8
Speakers Woofer / midbass PA255-8 25.4cm (10 inches) offer an excellent compromise between high power handling, low-encumberance, smooth frequency response and low distortion.
This model can accommodate all kinds of application: from the extra home theater speaker design, baffle construction for instrument or mobile sound, it easily integrates with your sound projects through a robust design and an accessible connectivity.
Its low mass paper membrane reinforced with carbon fiber, the ferrite magnet / ceramic and vented structure provide restitution deep bass frequencies with well-defined contours. The design of the speaker provides excellent resistance to thermal stresses, which allows it to operate at high power without causing uncontrolled distortion.
SeriesPro Audio Series
ReferencePA255-8
Weight5.35 kg
TypeWoofer / Midbass
Nominal diameter25.4 cm
RMS power300 watts
Max power600 watts
Impedance8 ohms
Sensitivity92.6 dB @ 2.83V/1m
Frequency Response46 - 3,500 Hz
Voice Coil Diameter51 mm
Magnet Weight50 oz.
DC Resistance (Re)5.5 ohms
Voice Coil Inductance (Le)1.49 mH
Resonant Frequency (Fs)50.5 Hz
Mechanical Q (Qms)8.49
Electromagnetic Q (Qes)0.66
Total Q (Qts)0.61
Diaphragm Mass Inc. Airload (Mms)42.3g
Mechanical Compliance of Suspension (Cms)0.24 mm/N
Surface Area Of Cone (Sd)346.4 cm²
Volume of Displacement (Vd)173.2 cm³
BL Product (BL)10.6 Tm
Compliance Equivalent Volume (Vas)41.2 liters
Maximum Linear Excursion (Xmax)5 mm
Cone / Diaphragm MaterialPaper / Carbon Fiber Cone
Surround MaterialCloth
Voice Coil Wire MaterialCopper
Voice Coil FormerKapton® / Polyimide
Basket/Frame MaterialSteel
Magnet MaterialFerrite
Overall Outside Diameter254 mm
Overall Depth125 mm
Baffle Cutout Diameter232 mm
# Mounting Holes8
Speaker Power (W RMS)300.0
Speaker TypeMidbass
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)254.0
Diaphragm typePaper
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)96.0
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)46
Highest frequency (Hz)3500
