DAYTON AUDIO PC105-4 Full Range Speaker Driver
With the PC105-4, Dayton Audio unveils a full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers smooth, natural sound reproduction. It is ideal for DIY construction or repair of small audio systems, or as a building block for more complex assemblies requiring several drivers of the same type.
Reference : 19216
18,90 €tax incl.
15,75 € tax excl.
Shipping date: 24-04-2025.
DAYTON AUDIO PC105-4 Full Range Speaker Driver 40W 4 Ohm 90.3dB 80Hz-15kHz Ø12.6cm
Photo of DAYTON AUDIO PC105-4 speaker driver
With the PC105-4, Dayton Audio unveils full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers smooth, natural sound reproduction. It is ideal for DIY construction or repair of small audio systems, or as a building block for more complex assemblies requiring several drivers of the same type. Despite its small size, the PC105-4 4" delivers good sound reproduction and is suitable for a wide range of uses. It performs well when used as a midrange driver in a three-speaker system. It can also be used in the design/repair of portable speakers, line arrays, soundbars or any other configuration requiring speaker networking.
Here are some of the highlights of the Dayton Audio PC105-4:
  • Poly-damped woven fiberglass cone.
  • Copper cap maintains inductance and extends frequency response.
  • 25.4mm ventilated aluminum voice coil for high power handling.
  • High-energy ferrite magnet for high efficiency and performance.
  • Harmonious frequency response over a wide soundstage (ideal for single-HP systems).
Dimensions and measurements of the DAYTON AUDIO PC105-4 speaker driver
Product typeFull-range speaker driver
Power handling40Wrms
80W max.
Impedance4 ohm
Frequency response80Hz-15kHz
Sensibility90.3dB 2,.3V/1 m
Nominal diameter10.16cm (4")
Bolt Circle Diameter11.3cm (4.45")
Voice coil diameter2.54cm (1")
Depth5.99cm (2.36")
Mounting holes4
thiele-small parameters
Resonant Frequency (Fs)81.4Hz
DC resistance (Re)3.3 ohm
Voice Coil Inductance (Le)0.32mH
Mechanical Q (Qms)2.17
Electromagnetic Q (Qes)0.67
Total Q (Qts)0.51
Compliance Equivalent Volume (Vas)0.13ft³
Mechanical Compliance of Suspension (cms)0.92mm/N
BL Product (BL)3.3T·m
Diaphragm Mass Inc. Airload (Mms)4.2g
Maximum Linear Excursion (Xmas)2mm
Surface Area of Cone (Sd)52.8cm²
Materials of construction
Cone MaterialPoly-composite
Surround MaterialCaoutchouc
Voice Coil Wire MaterialCCA
Voice Coil FormerAluminium
Basket / Frame MaterialAcier
Magnet MaterialFerrite
Recommended enclosure volume
Sealed Volume0.07ft³
Sealed F3136Hz
Vented Volume0.15ft³
Vented F380Hz
Package1x DAYTON AUDIO PC105-4 speaker driver
Speaker Power (W RMS)40.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)107.0
Diaphragm typeComposite alloy
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)80
Highest frequency (Hz)15000
With the PC105-4, Dayton Audio unveils a full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers...
