Bon haut parleur. Utiliser en médium dans un 3 voies. Fait le boulot mais un vrais médium aurait été plus performant. Attention pas top dans les aigu. Bon pour un 2 voies avec tweeter mais ne le remplace pas.
A full range speaker, compact and beautiful finishes. Ideal for building / repairing a small audio system or as a building block for more complex assemblies requiring multiple speakers of the same type.
Despite its small size, the PC105-8 4" gives a good sound reproduction and is suitable for many uses. It works well when used as a mid-range speaker in a three-speaker system. It can also be used in the design / repair of portable speakers, line arrays, sound bars or any other configuration requiring speaker networking.
The cone is fiberglass with a shape designed to respect the signal in a natural way. The coil and the pole are vented to better manage the high power. The PC105-8 4" is equipped with a high energy ferrite magnet for increased performance and efficiency. A harmonious response and true reproduction of the broad spectrum makes it an ideal speaker for single-hp systems..
SPECIFICATIONS | |
Speaker Type | Full Range |
Power | RMS : 40 Watts Max : 80 Watts |
Impedance | 8 Ohm |
Dimensions | Ø107 mm x 102 mm |
Frequency Response | 80 - 15000 Hz |
Sensitivity | 86.3 dB @ 2.83V/1m |
Coil diameter | 2.54 cm |
Resonant Frequency | 84.8 Hz |
Nominal Diameter | 4 Pouces / 10.7 cm |
DC Resistance (Re) | 6.7 Ohm |
Voice Coil Inductance (Le) | 0.54 mH |
Electromagnetic Q (Qes) | 0.88 |
Mechanical Q (Qms) | 2.29 |
Total Q (Qts) | 0.64 |
Diaphragm Mass including airload (Mms) | 4.2g |
Mechanical complicance of suspension (Cms) | 0.84 mm/N |
Surface of Cone (Sd) | 52.8 cm² |
Maximum linear excursion (Xmax) | 2.0 mm |
Weight | 720g |
Speaker Power (W RMS) | 100.0 |
Speaker Type | Full range |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 107.0 |
Diaphragm type | Paper |
Diaphragm type | Carbon kevlar |
Diaphragm type | Glass fiber |
Diaphragm type | Titanium |
Diaphragm type | Mylar |
Diaphragm type | Polypropylene |
Diaphragm type | Composite alloy |
Diaphragm type | Fabric |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | 86.0 |
Max Linear Excursion (Xmax) (mm) | 2.0 |
Lowest frequency (Hz) | 80 |
Highest frequency (Hz) | 15000 |
Average votes 4.8 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Adrien B.
Manuel F.
Manuel F.
thibault b.
