DAYTON AUDIO PC68-8 Speaker Driver Full Range
The Dayton Audio PC68-8 is a full-range speaker driver featuring a damped poly composite (woven glass fiber) cone, rubber suspension and high-energy motor. Offering excellent full-spectrum performance, controlled off-axis response and high efficiency, this loudspeaker delivers impressive power for its size.
Reference : 19969
13,40 €tax incl.
11,17 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
Dayton Audio PC68-8 Speaker Driver Full Range 20W 8 Ohm 86dB 110Hz-17kHz Ø6.3cm
Dayton Audio PC68-8 : Side view
The Dayton Audio PC68-8 is a full-range speaker driver featuring a damped poly composite (woven glass fiber) cone, rubber suspension and high-energy motor. Offering excellent full-spectrum performance, controlled off-axis response and high efficiency, this loudspeaker delivers impressive power for its size. Perfect for use in line arrays, soundbars, portable speakers or even car audio. The Dayton Audio will deliver high-fidelity, low-distortion sound for compact applications, all at exceptional value for money.
Dayton Audio PC68-8 : Measurements and dimensions
Speaker driver typeFull range
Nominal diameterØ63.5mm (2.5")
Power handlingRMS : 20W
Max : 40W
Impedance8Ω
Frequency response110Hz - 17kHz
Sensitivity85.6dB @ 2.83V/1m
Voice coil diameterØ19.05mm (0.75")
Weight295g
Total outer dimensions68 x 68 x 37mm
Magnet weight-
Thiele-Small parameters
Resonant frequency (fS)109Hz
DC resistance (RE)6.9Ω
Voice coil inductance (LE)0.47mH
Mechanical quality factor (QMS)2.27
Electrical quality factor (QES)0.88
Total quality factor (QTS)0.64
Compliance equivalent volume (VAS)1.3L (0.05ft³)
Mechanical compliance of suspension (CMS)1.05mm/N
Force factor (B·l)3.3T·m
Mechanical resistance (RMS)0.6N·s/m
Diaphragm mass inc. airload (MMS)2g
Moving mass (MMD)1.9g
Max linear excursion (XMAX)2mm
Air volume displaced at Xmax (VD)4.2cm³
Efficiency (η₀)-
Bandwidth efficiency (EBP)-
Cone surface area (SD)21cm²
Materials
ConePoly composite (glass fiber)
SurroundRubber
Voice coil wireCCA (Copper)
Voice coil formerAluminum
FrameSteel
MagnetFerrite
Mounting informations
External dimensions68 x 68 x 37mm
Cutout diameterØ64mm (2.52")
Depth37.1mm (1.46")
Bolt circle diameter-
Number of mounting holes4
Optimum cabinet size
Sealed volume1.7L (0.06ft³)
Sealed F3145Hz
Vented volume0.2.8L (0.1ft³)
Vented F377Hz
Speaker Power (W RMS)20.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)63.0
Diaphragm typeGlass fiber
Diaphragm typeComposite alloy
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)110
Highest frequency (Hz)17000
DAYTON AUDIO PC68-8 Speaker Driver Full Range 20W 8 Ohm 86dB 110Hz-17kHz Ø6.3cm
The Dayton Audio PC68-8 is a full-range speaker driver featuring a damped poly composite (woven glass fiber) cone, rubber suspension and...
