The PK165-8 Dayton Audio speaker delivers midrange frequencies with low distortion and good sensitivity in this range. This speaker can be used as a main audio source in a compact sound system as well as a midrange / bass speaker in a more complex installation. Its frequency band extends in the low frequencies up to 95 Hz with a sufficient reactivity to enrich the listening in a significant way.
From the point of view of the sounds, this model provides a clear and neutral sound that will leave intact the nuances of the sound and the subtleties of the amplifier. The PK165-8 is a relatively demanding speaker in terms of power that will give very convincing results in medium and high powers. Used with a decent amplifier, it will provide a very satisfying result in a high-fidelity installation.
Built in a steel structure, the PK165-8 features a Kevlar reinforced paper cone, an acoustic treatment cloth, a ventilated pole piece and an aluminum coil wound on a polyimide former. An efficient manufacturing process makes this speaker a practical and affordable solution for a wide range of needs.
Spécifications | |
Speaker type | Medium |
Power | RMS : 100 Watts Max : 200 Watts |
Impedance | 8 Ohm |
Dimensions | Ø165 mm x 75.2 mm |
Frequency Response | 95 - 9000 Hz |
Sensitivity | 91.4 dB @ 2.83V/1m |
Voice Coil Diameter | 3.8 cm |
Resonnant Frequency (Fs) | 91.5 Hz |
Nominal Diameter | 8 Pouces / 20.3 cm |
DC Resistance (Re) | 6.8 Ohm |
Voice Coil Inductance (Le) | 0.81 mH |
Electromagnetic Q (Qes) | 0.77 |
Mechanical Q (Qms) | 7.93 |
Total Q (Qts) | 0.7 |
Diaphragm Mass Including Airload (Mms) | 10g |
Mechanical Complicance of Suspension (Cms) | 0.3 mm/N |
Surface Area of Cone (Sd) | 113.1 cm² |
Maximum Linear Excursion (Xmax) | 1.5 mm |
Speaker Power (W RMS) | 100.0 |
Speaker Type | Midrange |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 152.0 |
Diaphragm type | Carbon kevlar |
Diaphragm type | Kevlar |
Efficiency / Sensitivity (dB) | 91.0 |
Max Linear Excursion (Xmax) (mm) | 1.5 |
Lowest frequency (Hz) | 95 |
Highest frequency (Hz) | 9000 |
