DAYTON AUDIO PM180-8 Speaker Driver Midbass 30W 8 Ohm 94.4dB 55Hz - 12kHz Ø16.5cm
The Dayton Audio PM180-8 bass-midrange driver is based on the same design type as the Point Source broadband driver range. It will allow the design of multi-way loudspeakers with a wide frequency band reproduced in the midrange and lowrange midrange.
Reference : 13617
112,00 €tax incl.
93,33 € tax excl.
Last items in stock !
Shipping date: 25-04-2025.
DAYTON AUDIO PM180-8 Haut-Parleur Bas Médium 30W 8 Ohm 94.4dB 55Hz - 12kHz Ø16.5cm
The Dayton Audio PM180-8 bass-midrange driver is based on the same design type as the Point Source broadband driver range. It will allow the design of multi-way loudspeakers with a wide frequency band reproduced in the midrange and lowrange midrange. In addition, the contained size of this loudspeaker is ideal for mounting a system of reasonable size, without sacrificing performance and sound accuracy.
The PM range of low-medium drivers provides linear and integrated sound reproduction of the Nedymus Klippel engines, greatly reducing distortion. The membrane is made of paper reinforced with Kevlar and allows to obtain an excellent performance and a very nice precision. The PM range speakers can ideally be combined with a ribbon or planar-magnetic tweeter.
Product typeMidbass Speaker Driver
Nominal diameter16.5cm (6.5")
PowerRMS : 30W
Max : 60W
Impedance8 Ohm
Frequency response55Hz - 12kHz
Sensitivity94.4dB 2.83V/1m
Voice coil diameter2.54cm
Thiele-Small Parameters
Resonant frequency (Fs)53.2Hz
DC Resistance (Re)6.4 Ohm
Voice coil inductance (Le)0.68mH
Mechanical quality coefficient (Qms)4.13
Electromagnetic quality coefficient (Qes)0.30
Total quality coefficient (Qts)0.28
Compliance equivalent volume (Vas)1ft³
Mechanical compliance of suspension (Cms)1.1mm/N
Force factor (BL)7.7Tm
Diaphragm mass Inc. airload (Mms)8.2g
Max linear excursion (Xmax)4.6mm
Surface area of cone (Sd)130.69cm²
Materials
ConePaper / Kevlar
SurroundCloth
FrameAluminium cast
MagnetNeodymium
Mounting informations
Total external diameter180.1mm (7.09")
Cutout diameter145mm (5.71")
Depth72.6mm (2.86")
Bolt circle diameter170mm (6.69")
Number of mounting holes6
Optimum Cabinet Size (Measured with BassBox 6 Pro)
Sealed volume0.16ft³
Sealed F3150Hz
Vented volume0.31ft³
Vented F395Hz
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typeKevlar
Diaphragm typePaper
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)4.6
Lowest frequency (Hz)55
Highest frequency (Hz)12000
The Dayton Audio PM180-8 bass-midrange driver is based on the same design type as the  Point Source  broadband driver range. It...
