DAYTON AUDIO PM220-8 Speaker Driver Full Range Midbass Neodymium 40W 8 Ohm 95dB 43Hz-10kHz Ø20.3cm
The Dayton Audio PM220-8 is a full range / midbass speaker based on the same design as the excellent Point Source range, but designed for exotic high-performance applications requiring a wide frequency response in the mid to low-midrange range.
Reference : 14646
215,00 €tax incl.
179,17 € tax excl.
Dayton Audio PM220-8 Haut-Parleur Large Bande Bas Médium Néodyme 40W 8 Ohm 95dB 43Hz-10kHz Ø20.3cm
The Dayton Audio PM220-8 is a full range / midbass speaker based on the same design as the excellent Point Source range, but designed for exotic high-performance applications requiring a wide frequency response in the mid to low-midrange range. The PM220-8 provides optimum performance and high efficiency for many types of systems, such as vented loudspeakers, transmission lines or horn designs.
The PM range benefits from ultra-linear Klippel-optimized Neodymium motors with low distortion and low-loss Kevlar-reinforced paper diaphragms for high efficiency and extremely detailed reproduction. The wide frequency response range of these drivers makes them excellent complements for ribbon or planar-magnetic tweeters..
Speaker driver typeFull range
Midbass
Nominal diameterØ203.2mm (8")
Power handlingRMS : 40W
Max : 80W
Impedance8Ω
Frequency response43Hz - 10000Hz
Sensitivity95.4dB @ 2.83V/1m
Voice coil diameterØ25.4mm (1")
Weight2.1kg
Thiele-Small Parameters
Resonant frequency (Fs)49.1Hz
DC Resistance (Re)6.5Ω
Voice coil inductance (Le)0.8mH
Mechanical quality coefficient (Qms)5.08
Electromagnetic quality coefficient (Qes)0.41
Total quality coefficient (Qts)0.38
Compliance equivalent volume (Vas)2.22 ft.³
Mechanical compliance of suspension (Cms)0.98mm/N
Force factor (BL)7.21Tm
Diaphragm mass inc. airload (Mms)10.7g
Maximum linear excursion (Xmax)4.6mm
Surface area of cone (Sd)205.3cm²
Material
Cone materialPaper / Kevlar
Surround materialCloth
Frame / Basket materialCast Aluminium
Magnet materialNeodymium
Mounting Informations
Overall outside diameterØ221.5mm (8.72")
Baffle cutout diameterØ181.1mm (7.13")
Depth88.6mm (3.49")
Bolt circle diameter210.1mm (8.27")
Number of mounting holes6
Optimum Cabinet Size (Determined with BassBox 6 Pro High Fidelity)
Sealed volume0.52ft.³
Sealed F3103Hz
Vented volume1.1ft.³
Vented F362Hz
Speaker Power (W RMS)40.0
Speaker TypeFull range
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)203.0
Diaphragm typeKevlar
Diaphragm typePaper
Efficiency / Sensitivity (dB)95.0
Max Linear Excursion (Xmax) (mm)4.6
Lowest frequency (Hz)43
Highest frequency (Hz)10000
The Dayton Audio PM220-8 is a full range / midbass speaker based on the same design as the excellent Point Source range, but designed for...
