DAYTON AUDIO RS100P-8 Reference Speaker Driver Midbass Paper 30W 8 Ohm 86dB 90Hz - 12.5kHz Ø10cm
DAYTON AUDIO's Reference Series is now available with a paper cone! These pieces feature a patented paper cone combining natural pulp, synthetic Kevlar ® and glass fibers to create the perfect combination. Combining a sophisticated motor with 2 separate internal electrical shortcuts, and an ultra-rigid aluminum cone, the transducers in this series dethrone many more expensive designs.
Reference : 8494
49,00 €tax incl.
40,83 € tax excl.
Range"Reference Series"of DAYTON AUDIO is now available with a paper cone!
These pieces feature a patented paper cone combining natural paper pulp, synthetic Kevlar® and fiberglass to create the perfect combination.
Combining a sophisticated engine with internal 2 distinct electrical shortcuts, andacone in ultra rigid aluminum,the transducers of this series dethrone from their pedestal many more expensive realizations.
The objective here is tomaintain extremely low distortion rates, and this in spite of a holding in comfortable powerand anparticularly wide frequency response .
Successful bet if judging by the quality of listening and exceptional versatility of the unit RS100P-8.
And to spoil nothing, this loudspeaker adopts a look of the most attractive with its cone of black anodized color , herlarge suspension half rubber rollerhigh quality, sound CHASSIs ultra rigid owner and perfectly ventilated, and its connection plated Gold 24k.
https://www.audiophonics.fr/images2/8494/8494_daytonaudio_rs100p-8_3.jpg
Features:/ Strong>
  • Grâve medium
  • Largely ventilated motor eliminating compression phenomena that are harmful to the linearity and silence of the excursion
  • Very resistant cone Aluminum Anodized Black
  • Dual-track electric motor for minimum distortion
  • High quality building materials for increased durability
  • terminalsGold plated 24k
Specifications:
  • Diameter: 4 "/ 10.16cm
  • Power handling (RMS): 30 watts
  • Power handling (max): 45 watts
  • Impedance: 8 ohms
  • Sensitivity: 85 dB @ 1W / 1m
  • Frequency response: 90 - 12,500 Hz
  • Voice Coil Diameter: 1 "
  • DC Resistance (Re): 6.7 ohms
  • Voice Coil inductor (Le): 0.52 mH
  • Resonant Frequency (Fs): 94 Hz
  • Q Mechanical (QMS): 2.59
  • Q electromagnetic (SEQ): 0.67
  • Q total (Qts): 0.53
  • Area of ​​the cone (Sd): 15.52 cm2
  • Confvolume equivalent volume (Vas): 0.05 cfm
  • Maximum linear travel (Xmax): 3.5 mm
  • Cone / Diaphragm Material: Kevlar Paper / Cone
  • Contour material: Rubber
  • Other materials: Cast aluminum, Ferrite
  • Overall outer diameter: 3.875 "/ 9.8 cm
  • Overall Depth: 2.01 "
  • Mounting holes: 6
https://www.audiophonics.fr/images2/8494/8494_daytonaudio_rs100p-8_2.jpg
https://www.audiophonics.fr/images2/8494/8494_daytonaudio_rs100p-8_1.jpg
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)100.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)3.7
Lowest frequency (Hz)90
Highest frequency (Hz)12500
DAYTON AUDIO's Reference Series is now available with a paper cone! These pieces feature a patented paper cone combining natural pulp,...
