DAYTON AUDIO RS125P-8 Reference Speaker Driver Midbass Paper 30W 8 Ohm 87dB 70Hz - 10kHz Ø13cm
Range"Reference Series"of DAYTON AUDIO is now available with a paper cone! These pieces feature a patented paper cone combining natural paper pulp, synthetic Kevlar® and fiberglass to create the perfect combination. Combining a sophisticated engine with internal 2 distinct electrical shortcuts, andacone in ultra rigid aluminum, the transducers of this series dethrone from their pedestal many more expensive realizations.
Reference : 8495
47,90 €tax incl.
39,92 € tax excl.
Last items in stock !
Shipping date: 23-04-2025.
Dayton Audio RS125P-8 Reference Woofer Ø 12.5cm
https://www.audiophonics.fr/images2/DAYTON-AUDIO_LOGO.jpg
The objective here is tomaintain extremely low distortion rates, and this in spite of a holding in comfortable powerand anparticularly wide frequency response .
Successful bet if judging by the quality of listening and exceptional versatility of the unit RS125P-8.
And to spoil nothing, this loudspeaker adopts a look of the most attractive with its cone of black anodized color , herlarge suspension half rubber rollerhigh quality, sound chassis proprietary ultra rigid and perfectly ventilated, and its connection plated Gold 24k.
https://www.audiophonics.fr/images2/8495/8495_daytonaudio_RS125P-8_1.jpg
Features:/ Strong>
  • Multi-Purpose SpeakerWide Band
  • Largely ventilated motor eliminating compression phenomena that are harmful to the linearity and silence of the excursion
  • Very resistant cone Aluminum Anodized Black
  • Dual-track electric motor for minimum distortion
  • High quality building materials for increased durability
  • terminalsPlated Gold 24k
Specifications:
  • Nominal diameter: 5 "/ 12.5cm
  • Power handling (RMS): 30 watts
  • Power handling (max): 45 watts
  • Impedance: 8 ohms
  • Sensitivity: 87 dB @ 1W / 1m
  • Frequency response: 75 - 12,000 Hz.
  • Voice Coil Diameter: 1 "
  • Resistance DC (Re): 6.2 ohms
  • Voice Coil inductor (Le): 0.58 mH
  • Frequency Resonance (Fs): 76 Hz
  • Q Mechanical (QMS): 2.43
  • Q electromagnetic (SEQ): 0.45
  • Q total (Qts): 0.38
  • Area of ​​the cone (Sd): 19.00 cm2
  • Cone / Diaphragm material: Kevlar paper / cone
  • Contour material: Rubber
  • Other materials: Cast aluminum / Ferrite
  • Overall outside diameter 4.938 "
  • Overall Depth 2.25 "
  • # Mounting holes 6
https://www.audiophonics.fr/images2/8495/8495_daytonaudio_RS125P-8_2.jpg
https://www.audiophonics.fr/images2/8495/8495_daytonaudio_RS125P-8_3.jpg
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)130.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)70
Highest frequency (Hz)10000
2 reviews
pas mal
j'ai commandé ces medium pour une realisation perso, placé entre deux seas un u18 rnx et un 27tdfc . et bien il na pas a rougir au milieu, peut etre un manque de sensibilité,mais bon en ajustant le filtre ça passe. en plus il est beau .vraiment un bon rapport qualité prix
This review has been posted for DAYTON AUDIO RS125P-8 Reference Speaker Driver Midbass Paper 30W 8 Ohm 87dB 70Hz - 10kHz Ø13cm
une référence
les haut parleur de cette série sont vraiment d'un excellent rapport qualité prix
Range"Reference Series"of DAYTON AUDIO is now available with a paper cone! These pieces feature a patented paper cone combining natural...
