DAYTON AUDIO RS180-4 Reference Speaker Driver Midbass 60W 4 Ohm 89dB 39Hz - 3600Hz Ø18cm
The Reference Series brings a new generation of high-performance speakers. These speakers use a low distortion motor system and a rigid aluminum cone. Theseries reference can surpass woofers that cost several times the price!
Reference : 8233
85,00 €tax incl.
70,83 € tax excl.
This product is temporarily unavailable.
Dayton audio RS180-4 Woofer Reference 4 Ohm 17cm
Low distortion and high excursion capabilities provide exceptional clarity, detail and dynamics.
This woofer features a black and sturdy anodized cone, a 6-hole chassis, a rubber suspension, a solid aluminum phase part, and gold spring terminals.
Specifications:
  • Diameter: 17cm
  • Nominal Power (RMS): 60 watts
  • Rated power (max): 120 watts
  • Impedance: 4 ohms
  • Sensitivity: 88 dB @ 1W / 1m
  • Frequency response: 40 - 2,200 Hz
  • Coil diameter: 38 mm
  • Resistance DC (Re): 2.9 ohms
  • Resonant Frequency (Fs): 40.4 Hz
  • SMQ: 2.66
  • Qes: 0.62
  • Qts: 0.50
  • Material membrane: aluminum
  • Overall outer diameter: 180.5 mm
  • Overall Depth: 87 mm
  • Mounting holes # 6
More information :PDF Manufacturer RS180-4
https://www.audiophonics.fr/images2/8233/8233_daytonaudio_RS180-4_woofer_5.jpg
https://www.audiophonics.fr/images2/8233/8233_daytonaudio_RS180-4_woofer_6.jpg
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (mm)180.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)39
Highest frequency (Hz)3600
rs 180.4
pour ma part beau produit , bonne qualité de finition
pour le prix
This review has been posted for DAYTON AUDIO RS180-4 Reference Speaker Driver Midbass 60W 4 Ohm 89dB 39Hz - 3600Hz Ø18cm
The Reference Series brings a new generation of high-performance speakers. These speakers use a low distortion motor system and a rigid aluminum...
