DAYTON AUDIO RS180P-4 Reference Speaker Driver Midbass Paper 60W 4 Ohm 91dB 35Hz - 8000Hz Ø18cm
Reference : 11287
82,90 €tax incl.
69,08 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
Here is the DAYTON AUDIO RS180P-4, a low-distortion, high-performance, low-distortion (Woofer) HP with ultra-smooth frequency response.
The appearance and characteristics are similar to the original series, with their low distortion motor, 6 holes chassis, rubber contour, and solid aluminum strut. It is perfect in woofer, mid-woofer, or medium use. It consists of 3 parts: paper, Kevlar®, and fiberglass.
You will find below in the attached documents a PDF with the detailed characteristics of the RS180P-4.
HP Specifications:
  • Nominal diameter: 7 "(18cm)
  • Nominal Power (RMS): 60W
  • Maximum power: 90W
  • Impedance: 4 Ohm
  • Sensitivity: 90.8dB / 2.83V / 1m
  • Frequency Response: 35Hz - 8000Hz
  • Re: 3.1 Ohm
  • On: 0.47 mH @ 1kHz
  • Fs: 37.7Hz
  • QMS - QES - QTS: 1.98 / 0.48 / 0.39
  • Mechanical Suspension: 1.21 mm / N
  • Cone: Paper / Kevlar
Dimensions:
  • Surface of cone (Sd): 126.7cm²
  • Overall Outside Diameter: 180.5mm
  • Overall Depth: 81mm
  • Diameter baffle: 146mm
  • Mounting holes: 6
  • Weight: 1.8kg
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (mm)180.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)91.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)35
Highest frequency (Hz)8000
Voici un alternatif de remplacement
Acheté pour remplacer les hauts parleurs NAD 802,pas besoin de changer les filtres.Le résultat est bon!
This review has been posted for DAYTON AUDIO RS180P-4 Reference Speaker Driver Midbass Paper 60W 4 Ohm 91dB 35Hz - 8000Hz Ø18cm
