DAYTON AUDIO RS52AN-8 Speaker Driver Dome Midrange 60W 8 Ohm 89dB 500Hz - 14kHz Ø13cm
A dome-type midrange speaker, ideal for your loudspeaker construction and repair projects. The RS52AN offers a nice linearity in the frequencies, without overwriting the sound balance. This speaker has a rich and detailed sound with a good dynamic restitution that avoids auditory fatigue.
Reference : 12631
58,90 €tax incl.
49,08 € tax excl.
Shipping date: 25-04-2025.
RS52AN-8 2 "Medium Dome Speaker by Dayton Audio
Speaker Dayton Audio RS52AN-8
It enjoys a particularly accurate sound between 600 and 4000 Hz. It is therefore an ideal solution for a main speaker that can be combined with a serious speaker and a twitter to obtain a system of sound. convincing speaker. Its frequency range allows it to really occupy all the space between the tweeter & woofer to produce a faithful and pleasant sound and without audible gap in the final rendering.
RS52AN-8 un HP polyvalent
side view of speaker dome
The RS52AN-8 has a high off-axis response and is therefore less directional than traditional speakers. In this, it is also an ideal candidate for all the installations located in spaces with complex geometry (form of unconventional room, cockpit of car ... etc.)
Its rugged construction based on an aluminum structure and a metal grille make it a durable device that will fit perfectly with all other high quality speaker models..
SPÉCIFICATIONS
Speaker TypeMedium
PowerRMS : 60 Watts
Max : 120 Watts
Impedance8 Ohm
DimensionsØ130 mm  x 57 mm
Frequency reponse500 - 14000 Hz
Sensitivity89.4 dB @ 2.83V/1m
Voice Coil Diameter5.08 cm
Resonant Frequency341 Hz
Nominal Diameter2 inches / 51 mm
Resistance DC (Re)6 Ohm
Coil Inductance (Le)0.13 mH
Electromagnetic Q (Qes)1.18
Mechanical Q (Qms)3.16
Total Q (Qts)0.86
Air Diaphragm Mass (including air)(Mms)1.7g
Mecanical Compliance of Suspension (Cms)0.13 mm/N
Surface Area of Cone (Sd)26.4 cm²
Maximum Linear Extrusion(Xmax)1.0 mm
Speaker Power (W RMS)60.0
Speaker TypeMidrange
Impedance (Ω)8
Loudspeaker diameter (mm)130.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)1.0
Lowest frequency (Hz)500
Highest frequency (Hz)10000
A dome-type midrange speaker, ideal for your loudspeaker construction and repair projects. The RS52AN offers a nice linearity in the frequencies,...
