DAYTON AUDIO RS52FN-8 Speaker Driver
New
The Dayton Audio RS52FN-8 is a soft-dome midrange driver offering excellent off-axis response and superb midrange performance. Its 2” (5.1cm) damped fabric cone offers a linear response from midrange to low frequencies, allowing a smooth transition to the tweeters.
Reference : 20537
62,90 €tax incl.
52,42 € tax excl.
This product is temporarily unavailable.
Dayton Audio RS52FN-8Speaker Driver Midrange 60W 8 Ohm 90dB 500Hz-8500Hz Ø5.1cm
Dayton Audio RS52FN-8: Side view
The Dayton Audio RS52FN-8 is a soft-dome midrange driver offering excellent off-axis response and superb midrange performance. Its 2” (5.1cm) damped fabric cone offers a linear response from midrange to low frequencies, allowing a smooth transition to the tweeters. Its superior dispersion characteristics eliminate aspiration and other problems that can arise in typical two-way designs with large woofers. Its high-quality construction includes a cast aluminum faceplate, metal grille, vented chassis and copper-clad pole piece. This model is ideal for use with other Reference Series loudspeakers, but will also work perfectly with any high-performance loudspeaker.
Dayton Audio RS52FN-8: Measurements and dimensions
Speaker driver typeMidrange
Nominal diameterØ50.8mm (2")
Power handlingRMS: 60W
Max: 120W
Impedance8Ω
Frequency response500Hz - 4500Hz
Sensitivity90dB @ 2.83V/1m
Voice coil diameterØ50.8mm (2")
Weight544g
Total external dimensionsØ130 x 57mm
Thiele-Small parameters
Resonant frequency (fS)394.3Hz
DC resistance (RE)5.7Ω
Voice coil inductance (LE)0.12mH
Mechanical quality coefficient (QMS)4.27
Electric quality coefficient (QES)1.39
Total quality coefficent (QTS)1.05
Maximum linear excursion (XMAX)1mm
Surface area of cone(SD)26.4cm²
Materials
ConeSoft dome
SurroundCloth
Voice coil wireCopper
Voice coil formerAluminum
FrameCast aluminum
MagnetNeodymium
Mounting informations
External dimensionsØ130 x 57mm (Ø5.12" x 2.24")
Cutout diameterØ100mm (3.94")
Depth57mm (2.24")
Number of mounting holes6
Speaker Power (W RMS)60.0
Speaker TypeMidrange
Impedance (Ω)8
Loudspeaker diameter (mm)51.0
Diaphragm typeFabric
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)1.0
Lowest frequency (Hz)500
Highest frequency (Hz)8500
DAYTON AUDIO RS52FN-8 Speaker Driver Midrange 60W 8 Ohm 90dB 500Hz-8500Hz Ø5.1cm
The Dayton Audio RS52FN-8 is a soft-dome midrange driver offering excellent off-axis response and superb midrange performance. Its 2”...
