DAYTON AUDIO RS75-8 Speaker Driver Full Range 15W 8 Ohm 80.5dB 160Hz - 20kHz Ø7.6cm
Dayton Audio's Reference Series range offers a new standard of quality for their speakers. Featuring a low distortion motor with a copper ring, a copper cap and an aluminum phase connector, the RS75-8 exceeds the performance of many speakers at often much higher prices.
Reference : 13695
34,90 €tax incl.
29,08 € tax excl.
Last items in stock !
Shipping date: 29-04-2025.
Dayton Audio RS75-8
Dayton Audio RS75-8 Haut-Parleur Large Bande 15W 8 Ohm 80.5dB 160Hz - 20kHz Ø7.6cm
Dayton Audio's Reference Series range offers a new standard of quality for their speakers. Featuring a low distortion motor with a copper ring, a copper cap and an aluminum phase connector, the RS75-8 exceeds the performance of many speakers at often much higher prices. Its low distortion and smooth frequency response provide exceptionally clear and detailed sound reproduction, with a beautiful dynamic range. In addition, this model incorporates an anodized aluminum membrane, a rubber suspension and gold plated contacts.
Speaker driver typeFull range
Nominal diameterØ7.62cm (3")
PowerRMS : 15W
Max : 30W
Impedance8 Ohm
Frequency response160Hz - 20kHz
sensitivity80.5dB 2.83V/1m
Voice coil diameterØ1.52cm
Thiele-Small Parameters
Resonant frequency (Fs)185Hz
DC Resistance (Re)6.2 Ohm
Voice coil inductance (Le)0.32mH
Mechanical quality coefficient (Qms)5.12
Electromagnetic quality coefficient (Qes)1.35
Total quality coefficient (Qts)1.07
Compliance equivalent volume (Vas)0.004 ft³
Mechanical compliance of suspension (Cms)0.94mm/N
Force factor (BL)2.55Tm
Diaphragm mass inc. airload (Mms)1.23g
Maximum linear excursion (Xmax)1.3mm
Surface area of cone (Sd)12cm²
Materials
Cone materialAluminium
Surround materialRubber
Voice coil wire materialCopper
Voice coil formerAluminium
Frame materialCast Aluminium
Magnet materialAlNiCo
Mounting informations
Overall outside diameter7.19cm (2.83")
Baffle cutout diameter5.41cm (2.13")
Depth3.86cm (1.52")
Bolt circle diameter6.4cm
Number of mounting holes4
Optimum cabinet size (measured with BassBox 6 Pro)
Sealed volume0.017ft³
Sealed F3170Hz
Vented volume0.029ft³
Vented F3104Hz
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)76.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)81.0
Max Linear Excursion (Xmax) (mm)1.3
Lowest frequency (Hz)160
Highest frequency (Hz)20000
Dayton Audio's Reference Series range offers a new standard of quality for their speakers. Featuring a low distortion motor with a copper...
