FOUNTEK FE86 Speaker Driver Full Range 15W 8 Ohm 83dB 95Hz - 20kHz Ø8cm (Unité)
The Fountek FE86 is a small, wideband speaker with a generous ferrite magnet system covering a frequency range of 95Hz to 20kHz. An ideal model for small speaker design.
Reference : 14851
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 25-04-2025.
Fountek FE86
Fountek FE86 Haut-Parleur Large Bande 15W 8Ω 83dB 95Hz - 20kHz Ø8cm
Fountek FE86 Haut-Parleur Large Bande 15W 8Ω 83dB 95Hz - 20kHz Ø8cm Fountek FE86 Haut-Parleur Large Bande 15W 8Ω 83dB 95Hz - 20kHz Ø8cm
Speaker typeFull range speaker driver
Nominal diameterØ8cm
PowerRMS : 15W
Max : 30W
Impedance8Ω
Frequency response95Hz - 20kHz
Sensitivity83.4dB
Voice coil diameterØ20.3mm (0.8")
Thiele-Small Parameters
Resonant frequency (Fs)86.4Hz
DC Resistance (Re)6.3Ω
Mechanical quality factor (Qms)2.4
Electromagnetic quality factor (Qes)0.688
Total quality factor (Qts)0.535
Compliance equivalent volume (Vas)1.53L
Force factor (BL)3.656 Tm
Diaphragm mass inc. airload (Mms)2.689g
Max linear excursion (Xmax)2.25mm
Surface area of cone (Sd)29.2cm²
SPL95.6dB
EBP126
Materials
ConeAluminum
Voice coil wireCopper
MagnetFerrite
Mounting informations
Total external dimensions80 x 80mm
Cutout diameterØ72mm
Depth41mm
Bolt circle diameterØ86mm
Number of mounting holes4
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)80.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)95
Highest frequency (Hz)20000
The Fountek FE86 is a small, wideband speaker with a generous ferrite magnet system covering a frequency range of 95Hz to 20kHz. An ideal model for...
