FOUNTEK FE87 Speaker Driver Full Range Aluminum 13W 8 Ohm 84dB 100Hz - 25kHz Ø8cm
3.0 / 5
Reference : 5920
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 22-04-2025.
FOUNTEK FE87 Broadband Speaker 7cm
This small, high-quality speaker is ideal for small and medium-sized speakers. Here is an ideal speaker for satellite monitor design without tweeter for a consistent and affordable result. With its 8 ohm impedance, it can be use MTM medium medium tweeter mode or with several speakers for a wide range of broadcast (Line Array).
Asubwoofer can provide better support in bass from 100Hz for a perfect fit in a 2.1 system.
https://www.audiophonics.fr/images2/5920/5920_FOUNTEKFE87_1.jpg
https://www.audiophonics.fr/images2/5920/5920_FOUNTEKFE87_2.jpg
Magnet system
Overall Dimensions
79X79X52.7mm
Magnet system type
ferrite shield
Net.Weight
0.56 kgs
Magnetic Gap Height
3mm
Nominal Power Handlng
13 W rms
B Flux Density
1.03T
Nominal Impedance
8 Ohms
Bl Product
3.1Tm
Sensitivity 1W / 1M
84dB
Max Linear Excursion
1mm+/-
Frequency Response
100-25,000Hz
T / S Parameter
Resonant frequency
101Hz
cms
1.181mm/NOT
Voice Coil
sd
27.34cm^ 2
Voice Coil Diameter
25mm
Vas
1.254L
Voice Coil Height
5mm
Mmd
1.991gm
Voice Coil Former
Black aluminum
mms
2.073gm
Voice Coil Wire
copper round
qms
3381
Number of Layers
2
Qes
0939
DC Resistance
6.776 Ohms
qt
0735
https://www.audiophonics.fr/images2/5920/5920_FOUNTEKFE87_3.jpg
https://www.audiophonics.fr/images2/5920/5920_FOUNTEKFE87_4.jpg
Speaker Power (W RMS)13.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)80.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)84.0
Max Linear Excursion (Xmax) (mm)1.0
Lowest frequency (Hz)100
Highest frequency (Hz)25000
2 reviews
Les remarques précédentes ne sont valables que pour une utilisation Line Array.
This review has been posted for FOUNTEK FE87 Speaker Driver Full Range Aluminum 13W 8 Ohm 84dB 100Hz - 25kHz Ø8cm
Très bon médium de 200Hz à 4kHz mais pas un large bande
Dans un caisson clos de 18 litres avec 4 hauts parleurs plus filtre de coupure numérique et une amplification dédiée, sur à la plage Bas médium à aigu le résultat n'est pas à la hauteur pour un large bande.
En dessous de 200hz la distorsion est trop importante pour de la HIFI
et au dessus de 6kHz, il baisse brutalement de 10db sans jamais remonté.
De 4kHz à 6kHz la distorsion remonte mais reste acceptable pour la Hifi.
Conséquence, obligation de passer à 3 voies avec un tweeter descendant au moins à 4kHz
Pour pondérer, entre 200Hz et 4Khz les mesures sont parfaites avec une réponse plate +/- 2db et une distorsion inférieure à 0.1%. Avec le caisson très amorti la réponse impulsionnelle est parfaite et l'écoute confirme les mesures avec un rendu sonore parfaitement détaillés sur tout type d'instrument.
