FOUNTEK FW168K Speaker Driver Midwoofer 50W 8 Ohm 87dB 70Hz - 4500Hz Ø16.5cm
This Fountek FW168K bass/midrange driver with aluminum cone and protective grille allows the restitution of frequencies from 70Hz to 4500Hz. Ideal for mounting multi-way speakers.
Reference : 14854
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 24-04-2025.
Fountek FW168K
Fountek FW168K Haut-Parleur Bas Médium / Médium 50W 8Ω 87dB 70Hz - 4500Hz Ø16.5cm
Fountek FW168K Haut-Parleur Bas Médium / Médium 50W 8Ω 87dB 70Hz - 4500Hz Ø16.5cm Fountek FW168K Haut-Parleur Bas Médium / Médium 50W 8Ω 87dB 70Hz - 4500Hz Ø16.5cm
Speaker driver typeMidwoofer
Nominal diameterØ16.5cm (6.5")
Power handlingRMS : 50W
Max : 100W
Impedance8Ω
Frequency response70Hz - 4500Hz
Sensitivity87.1dB/W/M
Voice coil diameterØ35.5mm
Voice coil height15mm
Weight1.45kg
Thiele-Small Parameters
Resonant frequency (Fs)48.6Hz
DC Resistance (Re)6.8Ω
Mechanical quality factor (Qms)2.319
Electromagnetic quality factor (Qes)0.524
Total quality factor (Qts)0.427
Compliance equivalent volume (Vas)15.1L
Mechanical compliance of suspension (Cms)0.684mm/N
Force factor (BL)7.896Tm
Diaphragm mass inc. airload (Mms)15.673g
Max linear excursion (Xmax)5mm
Surface area of cone (Sd)124.69cm²
EBP*93
Flux density1T
Material
ConeAluminum
Voice coil wireCopper
Voice coil formerAluminum
FrameDie cast
MagnetFerrite
Mounting informations
Overall external diameterØ182mm
Cutout diameterØ151.5mm
Depth86.5mm
Bolt circle diameterØ169.5mm
Number of mounting holes6
Speaker Power (W RMS)50.0
Speaker TypeMidbass
Speaker TypeMidrange
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)70
Highest frequency (Hz)4500
This Fountek FW168K bass/midrange driver with aluminum cone and protective grille allows the restitution of frequencies from 70Hz to 4500Hz. Ideal...
