Specifications | Magnet system | ||
Overall Dimensions | 217x88.8mm | Magnet system type | ferrite |
Net.Weight | 1.7Kg | Magnetic Gap Height | 5.8mm |
Nominal Power Handlng | 75 W | B Flux Density | 1.0T |
Nominal Impedance | 8 Ohms | Bl Product | 6.83Tm |
Sensitivity 1W/1M | 88dB | Max Linear Excursion | 4.35mm+/- |
Frequency Response | 35-3,000Hz | T/S Parameter | |
Resonant frequency | 35.7Hz | Cms | 0.948mm/N |
Voice Coil | Sd | 213.8cm^2 | |
Voice Coil Diameter | 36mm | Vas | 61.6 litre |
Voice Coil Height | 14.5mm | Mmd | 19.129gm |
Voice Coil Former | aluminum | Mms | 20.927gm |
Voice Coil Wire | copper | Qms | 2.258 |
Number of Layers | 2 | Qes | 0.683 |
DC Resistance | 6.8 Ohms | Qts | 0.525 |
