This latest-generation model incorporates the principles that made the former DMB-A unit's success esteem, and improves the concept to achieve a new performance threshold.
P>
This mid-range speaker now has a dome conical fabric of 50mm diameter , the surface of which is covered with a compound specifically chosen for its non-standard damping properties .
The winding of the moving part uses copper-plated aluminum wire Strong>permitting superior power handling, and reducing the resonance frequency to an optimum value for a better connection with the woofer.
The magnetic circuit composed of 2 symmetrically mounted armored magnets is based on a HiVi proprietary technology Strong>to allow a consequent increase in sensitivity, and a drastic reduction of harmonic distortions.
Thanks to its design and its mass, this exceptional engine also participates in the release of excess calories from the voice coil , assisted in this by a large acoustically ventilated chamber .
The result is a linear frequency sound, full of vitality, and the absence of distortion or coloring gives the sound scene a truly exceptional amplitude and naturalness.
Specifications:
HiViDMB-A:Dimensions
P>
HiViDMB-A:Frequency Response
P>
HiViDMB-A:Impedance Curve P>
P>
P>
P>
P>
