Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Ultra rigid cone made up of aluminum and magnesium alloy coated on the surface with a damping material promoting dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor consisting of 2 magnets mounted in symmetrical and ventilated
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
Specifications:
HiVi B3S:Dimensions
HiVi B3S:Frequency Response
HiVi B3S:Impedance Curve
Speaker Power (W RMS) | 15.0 |
Speaker Type | Full range |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 76.0 |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | 82.0 |
Max Linear Excursion (Xmax) (mm) | 3.0 |
Lowest frequency (Hz) | 300 |
Highest frequency (Hz) | 15000 |
