HiVi SWANS B4N Speaker Driver Midbass Aluminum 25W 8 Ohm 85dB 60Hz - 4000Hz Ø10.2cm
Reference : 4806
29,00 €tax incl.
24,17 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Ultra rigid cone made up of aluminum and magnesium alloy coated on the surface with a damping material promoting dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
https://www.audiophonics.fr/images2/4806_SWANS-HIVI-B4N_1.jpghttps://www.audiophonics.fr/images2/4806_SWANS-HIVI-B4N_2.jpg
https://www.audiophonics.fr/images2/4806_SWANS-HIVI-B4N_3.jpg
Specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 56Hz
  • Rated Power:25W
  • Sensitivity (2.83v / 1m): 85dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:10.4mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:5.1
  • Hey :4.0mm
  • XmaX:3.2mm
  • Cms:1114.1
  • Qms:3.91
  • Qes:0.63
  • Qts:0.52
  • Mms:6.8g
  • Sd:0.0053m2
  • Vas:4.5L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 5L
  • Recommended Cut-Off Frequency -3dB: 50Hz
  • Weight:0.9kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4806_SWANS-HIVI-B4N_4.jpg
HiVi B4N:Dimensions
https://www.audiophonics.fr/images2/4806_SWANS-HIVI-B4N_5.jpg
HiVi B4N:Frequency Response
https://www.audiophonics.fr/images2/4806_SWANS-HIVI-B4N_6.jpg
HiVi B4N:Impedance Curve
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)102.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)3.2
Lowest frequency (Hz)60
Highest frequency (Hz)4000
