HiVi SWANS D5.8 Speaker Driver Midbass Shielded High Performance 60W 8 Ohm 83dB Ø12.7cm
Reference : 4789
89,00 €tax incl.
74,17 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
HiVi's "D" loudspeaker range is a synthesis of all the technological advances made in recent years in the field of electroacoustics.
It is also the expression of the extraordinary know-how of a team of engineers and music lovers resolutely in the forefront.
Injected polypropylene cone
of mineral elements in order to densify the structure and improve rigidity.
Peripheral suspension in natural rubberloudspeaker to the loudspeaker, and participating in absorbing parasitic vibrationsoriginating at the surface of the cone
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor, combination of 2 magnets, one in Neodymium, the other in ceramics, mounted in symmetrical and ventilated
Can be used as a severe / medium unit on a 2-way system , or as a medium loudspeaker on a 3-way system more sophisticated.
https://www.audiophonics.fr/images2/4781_SWANS-HIVI-D5.8_2.jpg
https://www.audiophonics.fr/images2/4781_SWANS-HIVI-D5.8_3.jpg
Specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 52Hz
  • Rated Power:60W
  • Maximum Power Output:120W
  • Sensitivity (2.83v / 1m): 83dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 76mm
  • Length Coil:15.5mm
  • Mounting Type:Kapton
  • Composition Coil:Aluminum Wires Copper Plated
  • Composition Magnetic Circuit: Neodymium + Ceramic
  • BL:9.0
  • Hey :6.0mm
  • XmaX:4.8mm
  • Cms:522
  • Qms:3.07
  • Qes:0.42
  • Qts:0.37
  • Mms:17.3g
  • Sd:0.0087m2
  • Vas:5.6L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 8L
  • Recommended Cut-Off Frequency -3dB: 45Hz
  • Weight:1.8Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4781_SWANS-HIVI-D5.8_4.jpg
HiVi D5.8:Dimensions
https://www.audiophonics.fr/images2/4781_SWANS-HIVI-D5.8_6.jpg
HiVi D5.8:Frequency Response
https://www.audiophonics.fr/images2/4781_SWANS-HIVI-D5.8_5.jpg
HiVi D5.8:Impedance Curve
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)127.0
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)4.8
