Haut-Parleur Bas Médium Blindé 60W 8 Ohm 85dB 43Hz - 4000Hz Ø 15.2cm
The "D" loudspeaker range from HiVi synthesizes all the technological advances made in recent years in the field of electroacoustics. It is also the expression of the extraordinary know-how of a team of engineers and music lovers resolutely at the forefront.
This HiVi D6.8B loudspeaker is equipped with a polypropylene cone injected with mineral elements to densify the structure and improve rigidity. Its suspension is made of natural rubber, ensuring a long speaker life and helping to absorb parasitic vibrations that originate on the surface of the cone. The mobile crew is wound on a Kapton support for better power handling and heat resistance. The loudspeaker also has a powerful magnetic loudspeaker, a combination of 2 magnets, one in Neodymium and the other in ceramic and mounted symmetrically and ventilated. This speaker can be used as a bass/midrange unit on a 2-way system or as a midrange speaker on a more sophisticated 3 goose system.
Product type | Woofer / Midbass |
Nominal diameter | 15.24cm (6") |
Power | RMS : 60W Max : 120W |
Impedance | 8 Ohm |
Frequency response | 43Hz - 4000Hz |
Sensitivity | 85dB 2.83V/1m |
Voice coil diameter | 7.62cm (3") |
Thiele / Small Parameters | |
Resonent frequency (Fs) | 43Hz |
DC Resistance (Re) | 6.5 Ohm |
Mechanical Q (Qms) | 5.21 |
Electromagnetic Q (Qes) | 0.49 |
Total Q (Qts) | 0.45 |
Compliance equivalent volume (Vas) | 0.48ft³ |
Mechanical compliance of suspension (Cms) | 0.647mm/N |
BL Product (BL) | 8.7Tm |
Diaphragm Mass Inc. Airload (Mms) | 21.17g |
Maximum linear excursion (Xmax) | 5.3mm |
Surface area of cone (Sd) | 121.2cm² |
Material | |
Cone material | Poly |
Surround material | Rubber |
Voice coil wire diameter | CCA |
Voice coil former | Kapton / Polyimide |
Frame material | Aluminium |
Magnet material | Neodymium |
Mounting information | |
Overall outside diameter | 17.35cm (6.83") |
Cutout diameter | 13.5cm (5.315") |
Depth | 8.64cm (3.4") |
Bold circle diameter | 15.8cm (6.22") |
Fixation holes number | 6 |
Optimal cabinet size | |
Sealed volume | 0.2ft³ |
Sealed F3 | 81Hz |
Vented volume | 0.53ft³ |
Vented F3 | 42Hz |
Speaker Power (W RMS) | 60.0 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 152.0 |
Diaphragm type | Polypropylene |
Efficiency / Sensitivity (dB) | 85.0 |
Max Linear Excursion (Xmax) (mm) | 5.3 |
Lowest frequency (Hz) | 43 |
Highest frequency (Hz) | 4000 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Adrien F.
Stéphane n.
