HiVi SWANS M3N Widescreen Speaker Aluminum-Magnesium 3 "
Reference : 4807
19,90 €tax incl.
16,58 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Ultra rigid cone made up of aluminum and magnesium alloy coated on the surface with a damping material promoting dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
https://www.audiophonics.fr/images2/4807_SWANS-HIVI-M3N_1.jpghttps://www.audiophonics.fr/images2/4807_SWANS-HIVI-M3N_2.jpg
https://www.audiophonics.fr/images2/4807_SWANS-HIVI-M3N_3.jpg
Specifications:
  • Nominal Impedance:
  • Resonant Frequency: 91Hz
  • Rated Power:15W
  • Sensitivity (2.83v / 1m): 82dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 20mm
  • Length Coil:9.0mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:3.0
  • Hey :3.0mm
  • XmaX:3.0mm
  • Cms:1172
  • Qms:3.57
  • Qes:1.03
  • Qts:0.80
  • Mms:2.6g
  • Sd:0.0030m2
  • Vas:1.5L
  • Recommended Type of Load: Close
  • Recommended Load Volume: 1.6L
  • Recommended Cut-Off Frequency -3dB: 97Hz
  • Weight:0.55kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4807_SWANS-HIVI-M3N_4.jpg
HiVi M3N:Dimensions
https://www.audiophonics.fr/images2/4807_SWANS-HIVI-M3N_5.jpg
HiVi M3N:Frequency Response
https://www.audiophonics.fr/images2/4807_SWANS-HIVI-M3N_6.jpg
HiVi M3N:Impedance Curve
Speaker TypeFull range
Impedance (Ω)75
Loudspeaker diameter (mm)76.0
Diaphragm typeAluminium
2 reviews
extraordinaire
Un petit LB extraordinaire (comme le B3S), son pur, propre, net et détaillé. Utilisable à partir de 100Hz à faible niveau, ou à partir de 200 Hz à plus fort niveau. Parfait jusqu'à 20 kHz avec un peu de correction. Et il est beau !
This review has been posted for HiVi SWANS M3N Widescreen Speaker Aluminum-Magnesium 3 "
Mais comment font-ils ?...
... pour pondre un tel petit large-bande à ce prix ?
L'écouter c'est l'adopter. Et adopter une paire de M3N (ou B3S) en satellites avec un petit sub de 8" et un MiniDSP 2x4 c'est faire des économies énormes ;-)
Montez ce petit cygne dans un petit cube de 10 à 15 cm de côtés, vous m'en direz des nouvelles !
