HiVi SWANS M5N Speaker Driver Midbass Aluminum Magnesium 35W 8 Ohm 87dB Ø12.7cm
Reference : 4784
33,90 €tax incl.
28,25 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
The "M" series speakers were introduced for the first time through the "DIVA" range of the speaker manufacturer Swans.
The success of this collaboration was immediate, and the speakers were awarded for their exceptional quality / price ratio at the Home Entertainment Show of 2000.
Ultra rigid cone made of an alloy of aluminum and magnesium coated on the surface with a damping material that promotes dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
Can be used as a severe / medium unit on a 2-way system , or as a medium loudspeaker on a 3-way systemmore sophisticated.
https://www.audiophonics.fr/images2/4776_SWANS-HIVI-M5N_1.jpghttps://www.audiophonics.fr/images2/4776_SWANS-HIVI-M5N_2.jpg
https://www.audiophonics.fr/images2/4776_SWANS-HIVI-M5N_3.jpg
Specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 47Hz
  • Rated Power:35W
  • Maximum Power Output:70W
  • Sensitivity (2.83v / 1m): 87dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:10.4mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: ferrites
  • Magnetic Shielding:/ Strong>Yes
  • BL:7.5
  • Hey :5.0mm
  • XmaX:2.7mm
  • Cms:1051
  • Qms:6.51
  • Qes:0.37
  • Qts:0.35
  • Mms:10.7g
  • Sd:0.0087m2
  • Vas:11.3L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 10L
  • Recommended Cut-Off Frequency -3dB: 48Hz
  • Weight:1.5Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4776_SWANS-HIVI-M5N_4.jpg
HiVi M5N:Dimensions
https://www.audiophonics.fr/images2/4776_SWANS-HIVI-M5N_6.jpg
HiVi M5N:Frequency Response
https://www.audiophonics.fr/images2/4776_SWANS-HIVI-M5N_5.jpg
HiVi M5N:Impedance Curve
Speaker Power (W RMS)35.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)127.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)2.7
Lowest frequency (Hz)50
Highest frequency (Hz)6000
