HiVi TRINITY6 Triaxial Broadband Speaker 6 "
Reference : 5319
173,00 €tax incl.
144,17 € tax excl.
here is theTRINITY 6ofHiVi, a high-end 3-way coaxial woofer that will turn your DIY speaker into an impeccable HiFi system.
Features:/ Strong>
  • 3-way coaxial speaker
  • Tweeter with circular ribbon
  • Medium double concentric ring
  • Cone woofer Polypropylene
  • Scattering surface studied
  • Covers a range from 55Hz to 40kHz
Midrange
General Data
Nominal Power Handling (Pnom) (W)10
Max Power Handling (Pmax) (W)25
Sensitivity (2.83v / 1m) (dB)88
Electrical Data
Nominal Impedance (Z) (Ω) 6
DC (Re) (Ω) 5.1
Voice Coil and Magnet Parameters
VC Diameter (mm)55.1
VC Length (H) (mm)7.5
VC FormerCCAW
VC FrameAL
Mygnet SystemShielded
Magnet FormerNeodymium
TS Parameters
Resonance Frequency (Fs) (Hz)65
woofer
General Data
Nominal Power Handling (Pnom) (W)40
Max Power Handling (Pmax) (W)80
Sensitivity (2.83v / 1m) (dB)85
Weight (M) (Kg)1.49
Electrical Data
Nominal Impedance (Z) (Ω) 4
DC (Re) (Ω) 3.2
VC Diameter (mm)76
VC Length (H) (mm)11.4
VC FormerCCAW
VC FrameAL
Magnet SystemShielded
Neodymium
Force Factor (BL) (N / A)8.9
Gap Height (He) (mm)6
Linear Excursion (Xmax) (mm)3
TS Parameters
Suspension Compliance (Cms) (uM / N)447
Mechanical Q (Qms)4.32
Electrical Q (Qes)0.44
Total Q (Qts)0.36
Moving Mass (Mms) (g)22.9
Effective Piston Area (Sd) (m2)0.0121
Equivalent Air Volume (Vas) (L)13.5
Resonance Frequency (Fs) (Hz)45
Speaker TypeFull range
