Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Rigid cone, Anodized aluminum coated on the surface with a damping material promoting dynamic stability
Peripheral suspension in transparent rubber
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor in neodymium
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
specifications:
HiVi U2S:Dimensions
HiVi U2S:Frequency Response
HiVi U2S:Impedance Curve
Speaker Power (W RMS) | 5.0 |
Speaker Type | Full range |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 50.0 |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | 83.0 |
Lowest frequency (Hz) | 200 |
Highest frequency (Hz) | 20000 |
